Help: Pulling to the right after tire rotation.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ddanjeong, Jan 4, 2021.
  1. Jan 4, 2021 at 4:41 PM
    ddanjeong
    ddanjeong [OP] Well-Known Member
    Dan
    19 OffRoad Double Cab
    265/75r16 General Grabber AT/X Diode Dynamics SS3 Sport Fogs / Ditch Lights UpTop Overland Bravo Roof Rack
    Did my first tire rotation of my General Grabbers ATX today at 5K. Front to rear / rear to front. No crossing.
    There was no pull before and the truck drove straight and true. (Alignment done not too long ago In October)
    Now that the rear tires came directly to the front, the truck pulls mildly to the right.
    I’m thinking that I may need to just wear them in for a couple hundred miles because the tires are in a new position they haven’t been in before.
    or... I might diagnose if I have radial pull in one of them tires now up front.
    do you think I should try switching the two fronts left to right / right to left and see if it pulls to the left?
    debating if I should hope to wear them in untill it drives straight or diagnose it further.
    You thoughts? Thanks guys in advance
    hiPSI likes this.
  2. Jan 4, 2021 at 4:42 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Swap the fronts if you think it will help. Otherwise you might just have to wear them in.
  3. Jan 4, 2021 at 4:44 PM
    ddanjeong
    Dan
    That’s what I’m thinking. Just to wait and see a bit to see if it’ll wear in. maybe I’m stressing it unnecessarily
  4. Jan 4, 2021 at 4:52 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Sometimes it happens. Check air pressure and drive it a few weeks and let the tires wear in. I would have your alignment checked tho.
  5. Jan 4, 2021 at 5:08 PM
    ddanjeong
    Dan
    Right. Pressure is equal and good to go. Alignment seemed no issue up until post rotation judging by going from no pull to some pull. My guts telling me they just need to wear in for the new position they are in
    hiPSI[QUOTED] likes this.
  6. Jan 4, 2021 at 5:10 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Yea but... from experience a slight misalignment can be hidden by the tire wear. I would just run them like it is but just letting you know.
    ddanjeong[QUOTED][OP] likes this.
  7. Jan 4, 2021 at 5:17 PM
    ddanjeong
    Dan
    Thank you. I’ll keep that in mind
  8. Jan 4, 2021 at 7:41 PM
    ddanjeong
    Dan
    Anyone else have experienced something similar?
