HELP!!!! Punctured Condenser.
Discussion in 'Technical Chat' started by YotaMan2007, May 30, 2011.
  1. May 30, 2011 at 8:24 AM
    YotaMan2007
    YotaMan2007 [OP] Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    Being the idiot i am i accidentally punched a hole in my A/C condenser. what do i do? can it be welded shut?
  2. May 30, 2011 at 8:28 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    if you attempt to weld it or seal it, there is a good chance you are going to cause a restriction and your cooling cycle will no longer be very effective. There is also a chance of compressor damage if this happens.
  3. May 30, 2011 at 8:28 AM
    JayARRGHH
    JayARRGHH Well-Known Member
    Jay
    Bellingham, MA
    03 Tacoma SR5 TRD
    285/75/R16 Eldarado MTZ, Alpine CDE-102 Deck, DIY Snorkel, 2" Spacer Lift, Uniden Bearcat 880 CB, Custom over head console w/ map lights, CB Mount, and external CB speaker, 2 12" Kenwood Subwoofers, 300 Watt Alpine Amp, Alpine 3" lift 500# capacity
    MMMMMMMMMIGHTY TAPE! Just kidding. you could always cut it out and solder in a coupling? Idk if I'm familiar with a vehicle's condenser, I'm a plumber and used to regular condensers having copper pipes.
  4. May 30, 2011 at 8:29 AM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    They sell an aluminum weld kit at home depot ^
  5. May 30, 2011 at 8:29 AM
    Racerboy221
    Racerboy221 Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    Evacuate the system (if it hasn't already leaked out) and replace it. Bottom line.
  6. May 30, 2011 at 8:31 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    In lue of Memorial day I say Tactically Withdraw the system.
  7. May 30, 2011 at 8:38 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    i'm going to remove it and cap off the lines. my dad is saying to take it to a welding shop because its a quick and easy fix, and if the a/c doesn't work then buy the a new codenser. i'd rather replace the whole thing. good thing i rarely use the A/C. :eek:
  8. May 30, 2011 at 9:37 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    well the damaged condenser is out. noticed i'm missing a radiator bolt so thats something else i'll have to address.
  9. May 30, 2011 at 11:01 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    its in the middle of the cooling surface. :anonymous:
