Help putting photo on home screen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sgt.Tee, Mar 17, 2019.
  1. Mar 17, 2019 at 7:04 AM
    Sgt.Tee
    Sgt.Tee [OP] Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    Some message comes up can not find pictures, go to the manual etc. I had it on 3 screen on the radio because that came up and I left it alone.There is a 2 screen option, maybe that is my problem? and there are only 2 pictures on usb. Pictures are in JPG format... What am I doing wrong??
    Wanted to add I am using a SanDisk USB
  2. Mar 17, 2019 at 7:19 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    I'm not sure you can do that with the SR.
    But if you can, make sure the file names are correct.
    StartUpImage
    DisplayOffImage
    jmneill, kahanabob and tcjacado like this.
  3. Mar 17, 2019 at 7:25 AM
    Sgt.Tee
    Pete
    NE Pa
    I upgraded the radio, I have to read the manual. Something I am missing. I had the startup screen but can't go further
    daddy_o likes this.
  4. Mar 17, 2019 at 7:25 AM
    ICU1
    ICU1 Well-Known Member
    YouTube has some good videos covering this topic
  5. Mar 17, 2019 at 7:26 AM
    Sgt.Tee
    Pete
    NE Pa
    Ok I will check that out
  6. Mar 17, 2019 at 7:32 AM
    myaccountname
    myaccountname Well-Known Member
    Are you asking about custom start up and screen off images?
    awful camera work, but it does show the whole process.
    Note that the FOLDER names are specific, but the IMAGE name can be anything.
    https://www.youtube.com/watch?v=HkQqXYKF7H8
    TRD Larry, Tocamo, Gooseman11 and 2 others like this.
  7. Mar 17, 2019 at 7:38 AM
    Sgt.Tee
    Pete
    NE Pa
    Ok I did not name the pictures. I will go back and try this thanks
  8. Mar 17, 2019 at 8:04 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Folder Names must be correct. As Daddy_O said in post #2.
    Page 60 of the Media Manual on my 2016
    G.
  9. Mar 17, 2019 at 8:19 AM
    Sgt.Tee
    Pete
    NE Pa
    I renamed the phots but did not make a new file. I went out and the radio is still not seeing it, so I guess I have to change the pictures to a new file. All I did was rename the pictures. I guess separate files for each picture will do it?
  10. Mar 17, 2019 at 8:29 AM
    Garyji
    Gary
    Do you have them in the correctly named folder on the USB stick??? The photos can be named anything. The folders on the stick MUST be exact.
    G.
    r1200gs4ok and tcjacado like this.
  11. Mar 17, 2019 at 8:30 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I had to format the USB to FAT32 before the truck took it.
    Probably in the manual, but I went a thread here on the forum.
    prodemann, tcjacado and Garyji like this.
  12. Mar 17, 2019 at 9:04 AM
    Sgt.Tee
    Pete
    NE Pa
    No go. I do not have any of this in my manual because it is SR I guess. I upgraded the radio to GPS with a card. I did the separate folders and named them. My next and only option break out a new usb. This usb had songs on it that I deleted, so maybe, just maybe it is the thumb drive. I have to goggle this Fat32, thanks guys for all the advice, I have a couple of things to retry now
  13. Mar 17, 2019 at 9:55 AM
    Sgt.Tee
    Pete
    NE Pa
    No go, the usb is fat 32 already, I tried it again and tells me the same thing, cannot find usb. I am able to play music from usb so I know it works. I am taking a break from it, my brain hurts, thanks again guys.
    I installed the usb prior to setup so it should have enough time to find it
    jmneill likes this.
  14. Mar 17, 2019 at 10:55 AM
    Garyji
    Gary
    Seems weird that you can play music from the stick but not transfer the pics. My truck is just an SR5 with no premium audio or nav.
    Hope you get it figured out.
    G.
    jmneill likes this.
  15. Mar 17, 2019 at 10:59 AM
    jmneill
    SE
    X2^
    I remember having trouble with mine, aside from the FAT32. Something trivial, but it's been too long now.
    A few properly administered beers usually helps.
  16. Mar 17, 2019 at 11:03 AM
    tcjacado
    tcjacado Well-Known Member
    https://www.tacomaworld.com/threads/how-to-custom-startup-and-screen-off.301061/
    https://www.tacomaworld.com/threads/how-to-finally-setup-startup-and-display-off-images.472695/
  17. Mar 17, 2019 at 11:53 AM
    Sgt.Tee
    Pete
    NE Pa
    Lots of reading here, I appreciate the help. This will give me some things to try, I know I have a few things wrong that were mentioned in the threads
  18. Mar 17, 2019 at 11:55 AM
    Sgt.Tee
    Pete
    NE Pa
    Those were the days, having a few beers would help but I stopped drinking in 86. A whole other story why...
    TimC, tcjacado and jmneill[QUOTED] like this.
  19. Mar 17, 2019 at 1:48 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    Ok, finally figured it out. Here’s the low down..
    Must have:
    Fat32
    Case sensitive folder names
    Jpg or jpeg suffix on file
    Less than 15 character picture file name.
    Then...and only then...did it work.
  20. Mar 17, 2019 at 2:32 PM
    Sgt.Tee
    Pete
    NE Pa
    Thanks guys, I will be reading tonight and try again tomorrow, I formatted my usb to Fat and I made my folders first, labeled them and then I inserted the pictures. Sorry if I brought a old post to life but I do see some new comers are using it also. I have my links now for this Mod and tons of info on it here. Appreciate the old guys helping me out.......... Not that I am a spring chicken..............
    jmneill and Vbpiper like this.
