Help quick! Seized caliper?
Discussion in 'Technical Chat' started by burtonboards32, Oct 24, 2010.
  1. Oct 24, 2010 at 9:54 AM
    burtonboards32
    burtonboards32 [OP] Well-Known Member
    I am changing out the front pads on my 06 taco and passenger side is quick and easy but driver side I cannot push one piston in to install new pad. Sound like a seized caliper?
  2. Oct 24, 2010 at 10:04 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    try opening your brake resovouir
  3. Oct 24, 2010 at 10:04 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Unfortunately it does. Have you tried opening the bleeder to see if that helps? I know you might have to bleed the system afterwards, but thats better than buying a new caliper. I've never had trouble with 1 piston getting stuck. What are you using to compress it? A prybar?
  4. Oct 24, 2010 at 10:10 AM
    brians05taco
    Brian
    Lafayette,La.
    i use a big pair of channel lock pliers when changing mine and use the ole pads so not to damage the piston. works for me
  5. Oct 24, 2010 at 11:22 AM
    burtonboards32
    Well I took the caliper off and used old pad and c-clamp to lusk it back in. Put caliper back on and put new pad in then had someone push pedal and it work how it should. I guess I'll just keep an eye on caliper and hope it doesn't go bad
