Help! Random 09 Tacoma bump!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aiden06, Mar 10, 2023.
  1. Mar 10, 2023 at 1:58 PM
    Aiden06
    Aiden06 [OP] Member
    Aiden
    2009 Toyota Tacoma
    None
    Hi! I have a 2009 Tacoma Trd with a 4.0 liter v6. It has 250,000 miles. When driving from 20-40 mph below 2000 rpm I get a bump. The bump is sometimes hardly noticeable and sometimes really intense. It’s hard to re-create and is inconsistent. I drive it in 4th gear a lot and not in overdrive and in very rarely does it. But when I’m normal drive it happens often. The shop diagnosed it as a bad trans. Got the trans replaced, motor mounts, and trans mounts all replaced… still does it. Then they said it was u-joints and a carrier bearing. Those were replaced… still does it. With 5k down the drain I’m feeling kinda hopeless. It’s coming from the front of the truck and won’t happen above 2000rpm. I think it’s a misfire. I have replaced spark plugs and it still does it. Thinking about going and replacing the wiring and ignition coils. Then maybe fule injectors? I hope someone else out there has dealt with this. Thanks, Aiden.
  2. Mar 10, 2023 at 2:12 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    so, I know there was a TSB about 2nd gens feeling a bump when stopped when the truck settles at a light it feels like i got driven into. but yours is different?
    is it the trans kicking down to shift?
  3. Mar 10, 2023 at 2:45 PM
    Aiden06
    Aiden06 [OP] Member
    Aiden
    2009 Toyota Tacoma
    None
    No it’s not shifting, that’s the weird part. The bump is coming front the very front of the truck. It’s like a jolt. It’s only when slowly accelerating below 2000 rpm. I’m stumped. And the Mechanics are out of luck too…
  4. Mar 10, 2023 at 4:01 PM
    BigCountry762x39
    TL
    PNW, Oregon!
    wheel bearings are in good shape? any play in the CV axles? and the 4wd is for sure not engaged?
  5. Mar 10, 2023 at 4:19 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Slip yoke binding up and releasing? Any codes?
  6. Mar 10, 2023 at 4:19 PM
    Aiden06
    Aiden06 [OP] Member
    Aiden
    2009 Toyota Tacoma
    None
    Yeah, it’s in 2wd and the bearings and cv axles are fairly new.
  7. Mar 10, 2023 at 4:20 PM
    Aiden06
    Aiden06 [OP] Member
    Aiden
    2009 Toyota Tacoma
    None
    No codes, and we put a new slip yoke on. We thought that was the problem but it’s not.
  8. Mar 10, 2023 at 5:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    :eek:
    You mean the shop fired the parts canon at it, and started with the big stuff first.
    Yikes!
    It’s hard to tell from your description, this is one of those things I need to feel/experience myself.
    Either way, don’t go back to that shop. Ever.
    Steves104x4 likes this.
  9. Mar 10, 2023 at 5:17 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    With the truck idling is the tachometer needle steady or does it bounce a little bit?
  10. Mar 10, 2023 at 5:53 PM
    Aiden06
    Aiden06 [OP] Member
    Aiden
    2009 Toyota Tacoma
    None
    I definitely won’t be back… lol. The engine starts immediately and for the most part runs smooth. It may bounce a little. It sounds a little “clanky”. I’ll have to video the bump/jolt.
