Help, rear alloy rim is "stuck" to drum
Discussion in 'Wheels & Tires' started by Lunercrab, Oct 17, 2008.
  1. Oct 17, 2008 at 8:09 PM
    Lunercrab
    Lunercrab [OP] Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    Ok so I attempted to start my installation of my AAL, only to find that my rim is stuck to the drum. Anyone have any suggestion how to fix this? I was told by the dealer to just keep hitting it with a hammer til it pops off. I tried this with no luck, plus I was afraid of ruining something. I'm just curious if there was any other way of removing a "siezed" rim?
  2. Oct 17, 2008 at 8:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have always just used a rubber mallet, but there have been a couple of times when this did not work. Loosen the lug nuts, and jack the truck down to the ground. Usually the weight of the truck will break the rim free from the drum. Once you see the wheel is no longer stuck, jack the truck back up. :)
    AusBerg likes this.
  3. Oct 17, 2008 at 8:49 PM
    Drew793
    Drew793 Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    I had the same problem when I took the back wheels off to install wheel spacers. They weren't budging! lol Almost knocked the truck off the jack stands. lol
    I sprayed a little liquid wrench between the rim and drum (careful not to get it in the drum) and then did what Chris4x4 suggested and it freed it right up.
  4. Oct 23, 2008 at 7:32 AM
    OLEFART
    OLEFART Active Member
    northern illinois
    09 base
    integrated sirius, tonnaue cover
    i would sit on my but and kick with both feet at one side of the wheel , if doesnt break loose, then put lug nuts on loosly let it down ad push vehicle back and forth sideways till it breaks loose. when you get it off, wire brush both wheel inside and drum face in the area iit mates up then smear some lithium grease on that surface befor reinstallin wheel for next time you remove wheels. was a comon problem with my old f150 till i started doin this
  5. Oct 23, 2008 at 7:44 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    All good advice above, I've had to use them all of them. Once you get it off, do what OLEFART says. Makes it much easier next time around. Funny how the Alloys stick worse than the Steelies.
  6. Oct 23, 2008 at 7:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    As part of preventative maintenance for next time.....Put some Anti-Seize on the studs and on the surface of the drum (where the wheel comes in contact with it) and don't over-torque the lug nuts. I torque all my vehicle wheels to 100ft lbs.
  7. Oct 23, 2008 at 8:08 AM
    OLEFART
    northern illinois
    09 base
    yea anti seize will definatly last a lot longer than the lithium
  8. Oct 23, 2008 at 9:14 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    x2 on the rubber mallet.
    SpeySquatch likes this.
  9. Oct 23, 2008 at 7:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Anti seize is fine on the back of the wheel where it makes contact with the brake drum, but NOT recomended on lug nuts. You will not get an accurate torqe reading from the wrench, and could end up breaking the studs.
    Note how on things that Require anti sieze have a very small torqe value assigned to them, i.e. spark plugs are only about 30 ft.- lbs.
  10. Oct 23, 2008 at 7:17 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Coming from my oval track car mechanic days I can testify don't put anti-seize on the lugs. We had this brilliant idea we could get the lugnuts off faster in an unscheduled pitstop, so we put moly lube on the lugs. A wheel came off half way through the race.
    I just painted my rims, and the rears were stuck. I wiggled the truck to make sure it wasn't gonna fall off the jackstands, then I kicked the hell out of the tire with my heel. It broke loose.
  11. Oct 23, 2008 at 7:18 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    I have used wheel bearing grease on lugnuts for years and never had any issues.:)
  12. Oct 30, 2008 at 11:49 AM
    MikeM
    MikeM Well-Known Member
    Florence, KY
    17 TRD Sport 4x2 DCSB Blazing Blue Pearl
    Bright stuff
    Slowly and just in driveway, only loosen a little.
    Clean up wheel and hug with wire brush when you get them off and put on some anti seize.
    Hitting the wheel with anything solid is risky.
    Mike M
  13. Oct 30, 2008 at 12:05 PM
    HerNameIsLucy
    RIP Lucy.
  14. Oct 30, 2008 at 12:10 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    My friend owns a tire shop..... happens all the time they just give the tire a boot.... if that does not work then the give it a wack with a sledge(on the tire not the wheel.)
  15. Oct 30, 2008 at 2:24 PM
    Janster
    Jandy
    Lancaster, PA
    I don't understand how anti-seize can be harmful - I've been using it for years without any problems.
  16. Feb 18, 2013 at 12:33 PM
    Blue TRD
    Blue TRD New Member
    Don
    Connecticut
    2008 TRD Quad cab
    Nothing listed here worked, I swear I could drive the thing with no lug nuts. What finally worked was jacking it just off the ground and laying an 8 foot 2x4 flat under the truck against the bottom of the inside of the tire, then wacking it with a sledge from the oposite side of the truck. A big sledge!
  17. Feb 20, 2014 at 7:23 PM
    TacoMuley
    TacoMuley New Member
    4X4
    Lifted
    I had a stuck rear wheel on my 2008 Taco 4x4. I do some heavy off road a few times a year and the wheel had been on for only 2 years. I was rotating my tires. I banged on it with several mallets, used a crowbar to pry between the drum and inner side of the wheel and then pried on it with a 6 foot 1" bar between the spring and tire. Nothing! It would not budge. I re-installed the lugs then backed off 1 turn, lowered the jack and drove about 10' back and forth 3 times. NOPE!
    Finally, I left the lugs loose, took my Taco down the street and drove over 2 speed bumps at 40 MPH and vuala!! The wheel was loose but I still had to pry a bit. Corrosion I think.
  18. Feb 21, 2014 at 4:43 AM
    MikeM
    Florence, KY
    Bright stuff
    "Funny how the Alloys stick worse than the Steelies"
    The culprit is the increased corrosion of disimilar metals making contact.
    As far as use of Antisieze . Why do you think it is called "antisieze" !
    It is made for exactly for that, Main use is where steel and plated spark plugs used in Aluminum heads. Porsche used aluminum Lug nuts for many years until they changed over to Lug bolts. You needed to use antisieze on the threads, not ball socket, etc. If use of lubricant on the ball or cone portion of Lug Nut it will give incorrect torque readings and won't allow it to cinch tight when tightend.
    It the case of Aluminum wheels, I would recommend using it where the mating srfaces of the wheels contacts the drum or rotor. "Sparingly" or it will creep out over time.
    As far a Moly Lube on wheels studs, Just think about that for a second. Not a good idea, as you found out the hard way. If anything, once in a while a little oil on the threads.
  19. Feb 21, 2014 at 5:26 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Yes, I've also used antisieze on the drum face and on the lug nuts for years with no problems.
    Slight hijack:
    Manufacturer's do not spec torque based on dirty or corroded threads. The only way to get propwer bolt torque is with lubricated threads. The blog quoted above is pure bullshit - lubricating threads will not increase the torque and tesult in increased stress in the bolts. As a mechanical engineer with industry experience in bolt torque calculations for both nuclear pressure boundary piping bolt torque calculations and for non-pressure boundary mechanical applications, I can testify that lubricating the threads is the right thing to do. Not lubricating the threads results in corrosion and in attempting to apply torque to a corroded or dirty thread, you loose some of the applied force to the wheel by the necessary requirement to overcome the friction caused by the corrosion or dirt. ASME bolt torque calculations are based on clean, lubricated threads.
    Pnwadventure likes this.
  20. Feb 21, 2014 at 10:45 AM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    I got mine off kicking the tires.
