Help! Rear diff won't disengage.
Discussion in '1st Gen. Tacomas (1995-2004)' started by KerlyQ, Jan 12, 2014.
  1. Jan 12, 2014 at 12:20 PM
    KerlyQ
    KerlyQ [OP] Well-Known Member
    Jared
    BC Canada
    First and last truck Ill own.
    Magnaflow exhaust. Custom leather Katskinz. Fujita CIA. Custom canopy. Armourthane sprayed bed. Grey wire mod. Black American eagle wheels. Dick Cepeks FCII's. Black Emblems all around. TRD oil cap. Ignition Light Ring Mod. Blue LED dash and controls.
    I have a 2002 Tacoma Dbl cab TRD V6 4x4. So I did the "grey wire mod" in the summer and after tried the diff lock several times and everything worked great. I haven't used it for about 5-6 months and just yesterday was stuck in the snow and decided to use it. It locked perfectly and then when I went to unlock it nothing happened. It is stuck locked no matter how many times I push the button. The red dif lock button light remains lit while the button is depressed (off). I have done figure 8's and have driven in "S" patterns and have drove in circles. NOTHING! Remains locked. I have tried to listen for the Actuator and I can not hear it AT ALL. I have looked at the fuses under the dash and all are good. Is there a fuse in the engine bay fuse box that may be the culprit? I have read several threads but am trying to eliminate everything prior to pulling the actuator out. This is the only problem I have ever had with this truck and I have owned it for ten years. I have never done this and I will probably need some advice. If anyone with experience knows how to go about this I would be more than grateful.
  2. Jan 12, 2014 at 10:54 PM
    KerlyQ
    Jared
    BC Canada
    Delete This. Figured it out. It was the connectors. They were all gummed up and wet. Stupid.
