HELP!! Rear door stuck closed!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by musicmanjer, Dec 30, 2017.
  1. Dec 30, 2017 at 1:21 PM
    musicmanjer
    musicmanjer [OP] Member
    Jerry
    2006 Toyota Tacoma Quad cab
    Hey All,
    Ok, rear drivers side door is stuck closed. Unlock/lock mechanism sounds like its spinning inside without doing anything. It's stuck in the locked position and will not open from door handles. I've spent an hour trying to get it unlatched to no avail. I've even tried kicking it open from inside.
    Am I screwed, or does anyone have a way to get it open so i can replace the latch mech?
    Thanks,
    Jerry
  2. Dec 30, 2017 at 1:58 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    This happened on my Altima. Had to remove the door panel from the inside with the door shut. ( not easy) then I had to manually pull the release latch on the lock mechanism by hand. ( not easy) have fun
    wilcam47 likes this.
  3. Dec 30, 2017 at 1:59 PM
    4wheelslacker
    4wheelslacker Slacker by trade
    East Tenn
    2010 Taco crew shortbed
    2017 Trd struts,2018 Trd wheels,bakflip2 bed cover,ungraded sound system
    Totally agree
    Bebop[QUOTED] likes this.
  4. Dec 30, 2017 at 2:00 PM
    Bebop
    Nick
    I actually had to remove the driver side seat out of the passenger side of the car to get the panel off far enough. Altima coupe by the way so it was even worse.
  5. Dec 30, 2017 at 2:21 PM
    madsand
    madsand wanderer
    sandz
    Costa Mesa, CA
    2012 DBLCB LB sports 4x4 SC
    Icon 2.5" Remote Reservoir Extended Travel CDCV Icon tubular UCA Icon add a leaf Method NV wheels Nitto trail grappler MT 285/70/17 Weather Tech floor mat All Pro rock slider
    Lol turn off your child lock maybe ?
    JJ Customs likes this.
  6. Dec 30, 2017 at 2:44 PM
    musicmanjer
    Jerry
    Ok, thanks for the insight.
    So I looked at the panel on the Tacoma rear door and when the door is closed the seal is on the sides of the panel, in other words the door closes and the seal contacts the panel. Aside from busting or ripping the panel out, I can't see how to get to it to pop the snaps off to be able to pull it up and out. I am guessing the worm gear inside the lock mechanism is stuck in the lock position. These motors are known to burn up and stop working as this happened on a couple Prius'es I owned. Anyway, I am not even sure that if I can get to the cable that attaches to the lock, that I can even get it to unlatch. Seem that Toyota could have designed this better in my opinion.
  7. Dec 30, 2017 at 2:53 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    Could a slim jim from the outside be used to unlock the door? The kind police and locksmiths use? Without messing things up too much?
    Skyway likes this.
  8. Dec 30, 2017 at 3:32 PM
    musicmanjer
    Jerry
    Nope. if there were a key lock maybe a slimjim would work. Rear doors have no keylocks.
  9. Dec 30, 2017 at 3:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Open up the door on the other side and see how things are put together.
    It might give you some helpful clues on how to get the stuck one released with minimal damage.
    TacoZim, TrdSurgie and JoefromPTC like this.
  10. Dec 30, 2017 at 3:50 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    The rods are still there to grab no?
  11. Dec 30, 2017 at 4:00 PM
    musicmanjer
    Jerry
    No rods. Cables like on a bike break. I did pull the other door panel. Unless I can get to the unlock cable or latch, im completely screwed.
    SOSC and inwood customs like this.
  12. Dec 30, 2017 at 4:06 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Try the dealer, pricey but I’m sure your not the first.
  13. Dec 30, 2017 at 4:49 PM
    Markcal
    Markcal Well-Known Member
  14. Dec 30, 2017 at 4:58 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  15. Dec 30, 2017 at 5:01 PM
    Markcal
    I think I may have to watch the video again to make sure I get it.
    JimIowa, knottyrope, AZJuice and 2 others like this.
  16. Dec 30, 2017 at 5:05 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Dont remember what this thread is about, but i enjoyed the video.
  17. Dec 30, 2017 at 5:22 PM
    Bebop
    Nick
    Can you get through the door panel if you unbolt it and move it back a few inches. The door opening cables won't do anything if it's stuck on lock. You have to manually move the lock lever.
    Socal1tacoma5 likes this.
  18. Dec 30, 2017 at 5:39 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    That video didn't help me with my rear door, but it helped me with a few other things.
    whiskeytacos, AZJuice, rdjr17 and 3 others like this.
  19. Dec 30, 2017 at 8:10 PM
    JoefromPTC
    Joe
    I like your perspective and disposition!
  20. Dec 30, 2017 at 8:22 PM
    musicmanjer
    Jerry
    Guys thanks, the video helped a lot......got my mind off the door for a bit :)
    Anyway, When you close the doors, the panel is sandwiched in between the door frame and the door, and as I said earlier, the panel contacts the seal. I can't see any way to pull the panel without destroying it. BUT, once that happens, "Bebop" says the cables won't do a thing, and since the lock mech is encased in the plastic assembly, how would I manipulate the latch or lever to unlatch it from the striker even if I could access it??
    BTW, this is the WIFE'S Tacoma and she treats it like her child. SO, I'm kinda on the hook for this one.
    In my 35 years of doing mechanics, I've never run into this problem without me being able to resolve a locked door problem with a slimjim, pulling a door lock or pulling a panel. This downright SUCKS!!
