Help: Rear ome shocks with icon progressive.
Discussion in 'Suspension' started by THExBUSxDRIVER, Feb 28, 2011.
  1. Feb 28, 2011 at 10:23 AM
    THExBUSxDRIVER
    THExBUSxDRIVER [OP] Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Okay I need some insight guys.
    I was about to pull the trigger on a complete ome kit but then figured I could save some cash and put it towards something else.
    So I did some research and found that a lot of members are happy with the 3-leaf progressive (be it icon or wheelers). Most of my driving is street so I believe that the dakar leafs would be a bit much. I'm ok with the "cali nose high" look but only when it is very moderate and seeing that the progressive leafs only add 1.5" do you guys think it will be too much nose up?
    Also, the question I really want answered.
    Will the ome n182 nitro charged shocks be compatible with the 3-leaf progressive pack?
    Thanks in advance for the help guys, I'm too eager to lift my baby.
  2. Feb 28, 2011 at 10:26 AM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    For the nose high: it depends what you set the front hight at.
    The OME shocks should work just fine.
  3. Feb 28, 2011 at 10:30 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Yea I wanted a full 3" but I might leave it at 2.5 without the spacer. Too bad there isn't a 2" progressive leaf pack :(
  4. Feb 28, 2011 at 10:31 AM
    S.B.
    Sean
    What front lift are you doing?
  5. Feb 28, 2011 at 10:45 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Ome shocks with 885 coils. I'm looking around for a flip kit to go on the rear right now.
  6. Feb 28, 2011 at 10:47 AM
    S.B.
    Sean
    All-pro is the only one I know of.
  7. Feb 28, 2011 at 10:50 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I'd recommend something just a bit taller than 1.5". Typically these trucks (both gens) have about 1" of rake. If you want get the front done and risk lookin like a bro dozer for a day then decide on the rear. Jack up the truck front and rear and see what you like
  8. Feb 28, 2011 at 11:48 AM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    I at least want the front level with the rear, I think I'd be okay with the front being 1" higher. I'm on the hunt for shackle kits right now, I understand that ato makes them but has been re designing them and they are not in production right now. I tried allpro but my phone acts up on their site. Shackle kit should bring the rear to a total of 2.5 at the most.
