HELP: Rear Shock Problems
Discussion in 'Suspension' started by green01, May 11, 2011.
  1. May 11, 2011 at 5:52 AM
    green01
    green01 [OP] Well-Known Member
    Eric
    Windham, NH
    2.7 01 Tacoma
    Homemade front bumper, homemade rock sliders, 17" trd wheels with General Grabber AT2, homemade rear bike rack and lights.
    Hey guys, i purchased a pair of Skyjacker 8000 Nitro Shocks from Autoanything.com a year ago. the past year the suspension has been extreamly rough, enough that both shocks are blown now and have leaked a lot of oil. I believe that i have recieved the wrong set of shocks but both the disturber and manufacturer disagree.
    With the truck sitting level i only have 1.5inch of shock showing, i can bottom the shock out my pushing down on rear of truck. Currently the shock sits 16.25inches eye to eye (drivers rear).
    What do you guys think?
    2001 4x4 non trd, recalled frame. oem leafs replaced with frame
  2. May 11, 2011 at 5:59 AM
    Namyo
    Namyo -
    gah...seems like you should have more than 1" up travel.
  3. May 11, 2011 at 6:01 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    That shock doesn't even look like it remotely fits
  4. May 11, 2011 at 6:10 AM
    green01
    Eric
    Windham, NH
    2.7 01 Tacoma
    The plan is to get new shocks but i want to make sure they fit... the truck is still sitting level in the rear. Does anyone know the spec that my truck should have for a shock?
  5. May 11, 2011 at 6:15 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    what about 5100 rears?
  6. May 11, 2011 at 6:21 AM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Eric - has to be from all the mudding in NH a month back. Sounds like you should lift it, and then let me know when you want to go back out.
  7. May 11, 2011 at 6:23 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    5125s might be a little too long for his application
  8. May 11, 2011 at 6:24 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    No way can that shock be the correct length.
    I assume you have not lowered your truck.
    It has to contact the shock body any time it moves more than 1" lower than it is sitting empty.
    Go to the shock company and check the part numbers they show with what is on the shock.
    Deal with the mfg. not the place you bought them from.
    Put 400 lbs in the back and take a pic before and after it will be sitting on the shock body.
    Get some billies or even the stock shocks on after the pics before they break.
  9. May 11, 2011 at 6:32 AM
    green01
    Eric
    Windham, NH
    2.7 01 Tacoma
    i have been dealing with the manufacturer, he says the part number on the shock is the correct shock for my truck. The specs for the shock that's currently installed is Collapsed length: 14.82in Extended 24.84in Stroke 10in
  10. May 11, 2011 at 6:32 AM
    wtmtntaco
    wtmtntaco Well-Known Member
    NH
    03 TRD xtracab V6
    Bilstein 5100's at 2.5", Grey wire, Wheeler's 1.5 aal,
    So, I just went out and checked my truck, bilstein 5100's from RCD as per the sticker on them. The drivers side has about 2.5" of exposed shaft at rest with a resting length of 16", it also looks like it let go as there was oil in the bottom of the boot. The passenger side has 4 inches of exposed shaft with an 18.5" overall length at rest (eye to eye). The body of the drivers side is 11.25" length and the pass side is 12" in length. Don't know if that helps you Eric but thats what I got.
  11. May 11, 2011 at 6:39 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    yeah but from what i remember 5125s were available for lifted applications and hes running stock everything in the rear from what i can tell
  12. May 11, 2011 at 6:43 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    so?
  13. May 11, 2011 at 6:47 AM
    green01
    Eric
    Windham, NH
    2.7 01 Tacoma
    I PMed downsouth.. my rear suspension is stock besides these shocks. i went out and took measurements, thanks Rolf for the help, mine numbers are different.
    Both shocks are the same part number so they both have the same body length.
    Drivers Rear: Exposed 1.5", Body 13", Eye to Eye 16"
    Pass Rear: Exposed 2.5", Body 13", Eye to Eye 18
  14. May 11, 2011 at 7:04 AM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    10" stroke is too much for a stock height truck. Just get some 5100s they are good for 0-2 inches of lift and the only difference between them and the 5125s is that the 5100s already have the lengths figured out for you.
  15. May 11, 2011 at 10:30 AM
    green01
    Eric
    Windham, NH
    2.7 01 Tacoma
    Thanks for all help and info guys. Just ordered a set from Marco at Down South Motorsports, he was a big help and knew just want i needed. Ordered Bilstein 5125 shock with 8.13" Travel on the driver side, and the 8.6" Travel on the passenger side.
  16. May 11, 2011 at 10:40 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    uhhhhh........... just because its blowing fluid all over hell don't mean the shock tube is going to all but disappear, his springs would have to have a negative arc that'd almost touch the ground, look at it, the shock tube is about 2" exposed on level ground, I don't know what the fuck they go on but I'm betting it isn't a Toyota..
  17. May 11, 2011 at 10:47 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Good choice on the Billies , you're gonna luv'em. Not to be redundant bro'. I think you'll want to put the longer shock on the pass.side & the shorter one (obliviously) on the driverside...
  18. May 11, 2011 at 10:47 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    These dimensions are for applications with 3" of lift.
  19. May 11, 2011 at 10:51 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    As an after thought you tell the guy at the parts house he's full of shit....:p
  20. May 11, 2011 at 10:55 AM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    Yep, I just researched these shocks for my planned 3" lift and they are listed for lifts of up to 3.5" and therefore the salesman is on crack.
