Help! Red 4wd light flashing - 4wd won't engage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kbp68, Jul 13, 2011.
  1. Jul 13, 2011 at 8:06 AM
    kbp68
    kbp68 [OP] hey...I can change this!
    B.C.
    TRD Off Road DC/SB
    3" Pro Comp Lift/Level, ARB Winch Bumper, Superwinch UT3000,White Sport Grille, Bedliner'd rocker panels, Draw-Tite brake controller
    Monday my wife picked up my truck from the detailer. This morning I got in to drive it to work and noticed that the red 4wd light was flashing. I called my wife and she tells me that the light was flashing when she picked up the truck but she forgot to tell me:facepalm:. I switched it from 2wd to 4H and could hear the switch, the indicator came on (along with the red flashing indicator), but it didn't engage. I pulled over and stopped, and switched it to 4L. Indicator lights (including ABS) but still no engagement. WTF!? Any Ideas before I make the trip back to the detailer? Am I risking damage by driving it this way? (No strange noises - just the flashing red light)
    There were no issues prior to detailing, is there something that he could have unplugged, broken, etc?
  2. Jul 13, 2011 at 8:14 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Your locker button is On :notsure:
  3. Jul 13, 2011 at 8:17 AM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2021 Honda Ridgeline Sport AWD
    I think the red flashing indicator is the Rear differential lock.
    Check the switch on the dash.
    It shouldn't have caused any damage, it will only engage in 4 Low
  4. Jul 13, 2011 at 8:33 AM
    kbp68
    B.C.
    TRD Off Road DC/SB
    Problem solved. Thanks guys!
  5. Nov 21, 2011 at 6:23 PM
    moblarkus
    moblarkus Well-Known Member
    Mark
    British Columbia, Canada
    '06 Black Sand Pearl TRD Off-Road
    Satoshi grille, All-pro bumper, Allpro UCA's, Walker Evans coilovers, 10" Lightforce Blitz, PIAA 510's,Magnaflow cat-back, K&N CAI, Revtec rear blocks. TSB leafs, Firestone Ride-Rite air springs, Hopkins Agility brake controller.
    LMFAO. I've been spending the last hour trying to figure this out. Just put a Magnaflow on, as well as first oil change after seafoam treatment. Driveline light was flashing, rear diff button depressed, relieved!
  6. Nov 21, 2011 at 6:23 PM
    moblarkus
    Mark
    Zactly!
