Help! Regarding wiring my Heated seats SR5 2020
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Carsonogens, Jan 31, 2022.
  1. Jan 31, 2022 at 7:30 PM
    Carsonogens
    Carsonogens [OP] Carsonogens
    Carson
    Outer Banks Native
    2020 Tacoma SR5
    3" Rough Country Suspension Lift Hooke Road Bed Rack & Roll Bar Hooke Road Roof Rack W/Optional Lights Pedal Control Orange Virus tuning package (Not tuned) Diode Dynamics Switchback Halo Rings in headlights Custom Blacked out headlight interior AM TRD Pro Grille w/ Lights Bushwhacker Fender Flares Fab Fours Low-Profile Bull Bar Front Bumper Leather seats from Leatherseats.com 30 in LED Bar in Front bumper XRC 9500 lb Winch Lasfit LEDs
    Hey Guys,
    I installed heating pads when I switched my factory cloth seats to leather from Leatherseats.com. Fantastic product so far. Anyways I'm just getting around to wiring these bitches up. I have forked over most of the guides on this site/YouTube but I can't seem to find a video on my hardware/tacoma trim (electrical noob). Last time I had an issue I got great feedback from everyone here so I'm trying again.
    Here is my set up currently, sorry for the mess. Currently my seat will heat, while not very powerful, and the light/heat pad stays on when the truck is off. Bad. I have 3 wires. And a few questions :
    Black is ground (easy) and is grounded on the frame behind the steering wheel. Is there a better place nearby? Is that part of my power issue?
    Red wire has an inline fuse (Still in) and is tapped into the 10 Amp IG 1 No. 2. I feel pretty confident about this one. However in the 4th pic you can see the manufacturer intended these to be spliced.
    The third orange wire is the pesky one, I initially thought this was for the light, after splicing a green wire off a dash switch I got no power to the switch or the seat. After doing more research I found this was probably a low voltage wire (I am not sure about this) and I tapped it into this 7.5 Amp fuse for the USB. This got my seat working and got me here. However like I said when I turn the engine off, my heated seats continue to run, draining my battery.
    There is a relay that the seat heaters connect to, that then splits into these wires and the switch. Sooooo I shouldn't need additional hardware? Its a head scratcher for me, but I know this set up doesn't work.
    I have seen people splicing wires here in the center console, can someone point out which ones. Also, can I splice these 2 seat heaters together to be more efficient? how will that effect the rest of this build?
    Someone smarter than me fix this, please. I'm packing up the bong and will reassess in the morning.
    Last pic: I have seen people splice the power wires into pre-existing powered switches. I don't think any of these will work. I don't want to have any of them on while driving in the daytime. Am I wrong here? The LED Lightbar is just an empty switch that is another half completed project.
  2. Jan 31, 2022 at 7:31 PM
    Carsonogens
    Carson
    Outer Banks Native
    2020 Tacoma SR5
    Sorry a couple pictures got posted twice on the bottom
  3. Feb 1, 2022 at 4:45 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I “think” you’re tapped into an always on fuse.. maybe. I tapped mine into the s/htr when I ran mine. The dash light wire I ran into the tail, I think. I’ll have to double check. If you can see if the IGN2 is an always on fuse.
  4. Feb 1, 2022 at 7:57 AM
    Carsonogens
    Carson
    Outer Banks Native
    2020 Tacoma SR5
    I will attempt this now, thanks Jaxterra. Also trying to figure out what the deal is with this third wire....
  5. Feb 1, 2022 at 7:57 AM
    Carsonogens
    Carson
    Outer Banks Native
    2020 Tacoma SR5
    Thanks Eric! Did you wire a passenger seat as well?
  6. Feb 1, 2022 at 8:10 AM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    You're welcome, yea I wired both drivers and passengers. I may have put one on the s/htr and one on the sunroof… I’ll go look at my fuse panel once I get a chance.
    I think I tied the two lights to the panel or tail light.
    I feel like I have more add a fuses than that though but can think what else is there…
  7. Feb 4, 2022 at 11:33 AM
    Carsonogens
    Carson
    Outer Banks Native
    2020 Tacoma SR5
    Update: So I tapped into the 20A washer fuse and the 15A USB Fuse.
    Currently my driver seat is working as intended. Powers off with the vehicle, switch light and heater on. My passenger seat is still a dead switch.
    I have spliced both sets of the powered wires together in the add-a-fuse.
    My grounded wires are on two separate screws behind the driver wheel installed on the frame.
    Is anything popping out at you guys as to what could be wrong? Am I using the correct hardware for splicing?
