Help Releasing Electrical Connector Pins
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ACEkraut, Aug 14, 2016.
  1. Aug 14, 2016 at 11:54 AM
    ACEkraut
    ACEkraut [OP] Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I need some help removing the pins from this connector.
    72771768-8A79-431D-9F05-11FD0B4E06FC_zps_8d720193b5cbbbc17146cca5e60f3ef5beb3a5a8.jpg
    I have searched the web and TW with no success. Any links or advice is appreciated.
  2. Aug 14, 2016 at 12:51 PM
    deeve
    deeve Well-Known Member
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    I have used a paperclip or very small screwdriver before to release the individual wires. Something that is small and flat works best. They do make little tools for that I believe, but I've just used what I have around the house. Try those small slots. Push the wire forward a bit from the back and gently insert the tool from the front then gently tug the wire to pull it out. Sometimes is takes from practire.
  3. Aug 14, 2016 at 1:14 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    This might not be too helpfull, but there is almost always a special tool for doing so. Its amazing how well they work when you get the right one. As for what you need im not sure. Also some have barbs on them and are not meant to be removed without replacing. Usually they get damaged and you have to solder new ones on.
  4. Aug 14, 2016 at 1:19 PM
    caribe makaira
    Caribbean, Puerto Rico
    There's a lock that needs to be pulled first...it's the white center rim. Then you'll see where to press to release the secondary terminal lock.
    Can you provide other angle on the plug, top, bottom, side and ass end...be more helpful, also looks like a sealed connector.
  5. Aug 14, 2016 at 6:47 PM
    ACEkraut
    Aaron
    Durham, Maine
    Thanks guys. I was not successful. I can always redo that wiring if I ever figure out how to get the pins out.
  6. Aug 15, 2016 at 4:19 AM
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    You this.
  7. Aug 15, 2016 at 5:28 AM
    ACEkraut
    Aaron
    Durham, Maine
    Any source?
  8. Aug 15, 2016 at 5:33 AM
    98tacoma27
    Ben
    Not Beech Creek
  9. Aug 15, 2016 at 5:43 AM
    ACEkraut
    Aaron
    Durham, Maine
    Found it on Amazon, and other places. Have you tried the kit on that connector?
  10. Aug 15, 2016 at 5:44 AM
    ACEkraut
    Aaron
    Durham, Maine
  11. Aug 15, 2016 at 2:51 PM
    B ill y
    Billy
    It works on Toyota plugs and connectors. I use. On my vehicles.
  12. Aug 15, 2016 at 3:36 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
  13. Aug 15, 2016 at 3:57 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Are you planning on reusing the connector after rerouting the wire? The pic looks like female pins with an extra hook so they don't back out. Got a pic of the rear of the connector. May need to be pushed through and desoldered.
  14. Aug 15, 2016 at 5:09 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
  15. Aug 15, 2016 at 6:49 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Try youtube:
    Search for -> electrical connector pins
    Obviously not all vids are going to line up with what you're trying to do.
  16. Aug 16, 2016 at 5:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    igno1tus, Daves300 and Biscuits like this.
  17. Aug 13, 2020 at 11:05 AM
    Daves300
    Daves300 TTC#0333
    Texas
    2007 FJ
  18. Aug 13, 2020 at 11:17 AM
    ACEkraut
    Aaron
    Durham, Maine
    Holy thread rejuvenation Batman! This thread was dormant for 4 years! I forgot I ever started it...
    Daves300 and davidstacoma like this.
  19. Aug 13, 2020 at 12:03 PM
    vtdog
    vtdog Well-Known Member
    NH
    For us old guys (and I do mean old) that fix was originally known as a "Western Union" splice. In one of the variations, a square knot is made using the two ends and then the wire is spliced & taped (no solder on poles!) so that the knot takes the tension
  20. Aug 13, 2020 at 4:33 PM
    Daves300
    Daves300 TTC#0333
    Texas
    2007 FJ
    We've been waiting 4 years for you to come back and tell us how it turned out
    :confused::confused::confused::confused:
    davidstacoma likes this.
