Help removing a dent.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Jul 24, 2010.
  1. Jul 24, 2010 at 4:06 PM
    MxRacer190
    MxRacer190 [OP] Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Okay, I've gotten the "main" part of the dent out with a suction cup. Now, there are still two small dents at the top and bottom of the original dent. I've tried the "DIY hairdrier/air can" trick, and that didn't work. I've tried going under the fender and pushing them out, but I can't.
    I don't want to pay big $$ to have it removed, but I will if I have to. Any tips?
  2. Jul 24, 2010 at 4:26 PM
    wcm608
    wcm608 Well-Known Member
    Pittsburgh, Pa
    08 DC LB 4x4 SR5 Impulse Red
    why don't you try one of those paintless dent/ding repair guys.
  3. Jul 24, 2010 at 4:36 PM
    MxRacer190
    Georgia
    06 SR5 4x4 Indigo
    I'll probably have to do that, but just seeing if there are any other ways to do it.
  4. Jul 24, 2010 at 4:46 PM
    JudeLeBlanc
    JudeLeBlanc Active Member
    Baton Rouge, LA
    06 Single Cab PreRunner SR5
    Weather Techs
    its not hard to take off, you can just remove it and use a hammer to knock it out
  5. Jul 24, 2010 at 4:47 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    So you tried to pop it out by hand but couldnt? Maybe try a rubber malot? Idk..
  6. Jul 24, 2010 at 6:15 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Try a plunger ?
  7. Jul 24, 2010 at 6:23 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    leave it.....
  8. Jul 24, 2010 at 6:40 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Sold the ol girl
    try the inside with a hammer and a block of wood
  9. Jul 24, 2010 at 6:47 PM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    Heat that up with a heat gun and use a can of air upside down, that b*tch will pop
  10. Jul 24, 2010 at 6:47 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have never tried it myself, but I have been told that a basketball works well. Start with a flat basketball, shove it into the fender behind the dent, then inflate. My uncle did this on an old 79 Ford truck, the truck looks good now. Never saw it before the basketball trick, but can't see a dent now.
  11. Jul 24, 2010 at 8:49 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
  12. Jul 24, 2010 at 9:00 PM
    RAD
    RAD RAD Vendor
    THE RAD
    Socal
    2007 | TRD |1ST 2012+ CONVERSION
    2012 CONVERSION | A LOT OF TOTAL CHAOS & ICON DYNAMICS
    STORY behind that or it NEVER happened.
    Paintless Dent Remover FTW
  13. Jul 24, 2010 at 9:04 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Take out the cubby on that side and pop it back out, the dent is big ienough to have its own leverage. So a little elbow grease and it'll pop back out.
