HELP removing bed rails! stripped screws...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bolo, Mar 5, 2009.
  1. Mar 5, 2009 at 6:46 PM
    Bolo
    Bolo [OP] Well-Known Member
    San Diego
    2007 TRD Offroad
    Billet grill, nerf bars, TSB, Bilstein 5100s, Pioneer deck, Access Literider, shorty antenna
    I just got my access literider cover from fedex and i immediately started to install it. As a started to remove the rails, I found that many of the screws holding the rails on are not coming out. Even with the correct tools, many of the screws are stripped in there. I'm so pissed right now. I lent out my dremmel and dont have a screw extractor with me, so I don't know what to do. You guys have any tips? How the hell am I going to remove the screws to install my cover...?
  2. Mar 5, 2009 at 6:47 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Wait and get an extractor or chisel the tops off if possible. One swing should take the heads off.
  3. Mar 5, 2009 at 7:08 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
  4. Mar 6, 2009 at 6:26 AM
    Brunes
    Brunes abides.
    Rotorhead
    I'd use an extractor-Knock the heads off those and the studs are going to be a bitch to get out.
  5. Mar 6, 2009 at 6:31 AM
    Madchild
    Madchild Well-Known Member
    Bloomington MN
    Slim's HID, Tonnau Cover
    are the screw alum or steel? I would think if its Alum you can drill it out and the alum should shred itself.
  6. Mar 6, 2009 at 7:21 AM
    BlackRig
    BlackRig Well-Known Member
    Craig
    Riverside, IL
    09 TRD O/R AT
    What exactly is stripped? The heads of the screws? The threads? Or the nuts are spinning behind the bed? If the heads are srtipped, hacksaw blade behind the rails worked for me. If the threads are gone or the nuts are spinning try popping out the stroage compartments and reaching a hand back there with a set of vice grips to hold the nut. Worst case you may need to gain access to the nuts in the back and vice grip the bolt.
    I ran into the same trouble when I swaped my access cover to my new truck. Lesson learned. I replaced the screws for my cover with stainless steel bolts from the hardware store. Good luck.
  7. Mar 6, 2009 at 9:03 AM
    Bolo
    San Diego
    2007 TRD Offroad
    thanks for the advice guys. I ended up picking up some extractors and getting my drill back and eventually got them out and my cover installed. One of the screws took forever... Damn loctite.
  8. Mar 6, 2009 at 11:35 AM
    stro1965
    stro1965 Well-Known Member
    Bellevue, NE
    09 Timberland Mica Tacoma 4x4
    That happened to me too on one of my screws, stripped the head and it wouldn't budge. I was able to use a needle-nose vice-grip but it took a while. Easy-out just spun in the head.
  9. Mar 6, 2009 at 1:45 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    :worthless:
    Pictures of the cover my friend, pictures!
