Help - removing bolt from tailgate
Discussion in 'Technical Chat' started by JRFry, Dec 15, 2012.
  1. Dec 15, 2012 at 11:40 AM
    JRFry
    JRFry [OP] Well-Known Member
    Central PA
    '13 SR5 4X2 Long Bed
    ARE cap, ProMaxx stainless step bars
    I bought an EZDown tailgate damper. The instructions say to remove a bolt from the tailgate. They show someone using an allen wrench to do it. A 3/16 allen wrench fits, but the bolt's too tight. There's what looks like an adhesive between the hinge and the tailgate. You can see it in this picture.
    There's no way an allen wrench will loosen this--it'd snap. Any suggestions on what I can try?
  2. Dec 15, 2012 at 11:43 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Torx socket ?
  3. Dec 15, 2012 at 12:12 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Be sure to use a torx bit to avoid stripping the screw:
    From what I've read, though, '08+ trucks have the screws tack-welded in place. Mine was like that. Not sure how much effort it would take to break the weld. I think the EZ Down is advertised for '05-'07 only. You can open up the fiberglass liner and see how the screw is attached inside the tailgate.
  4. Dec 15, 2012 at 1:31 PM
    JRFry
    Central PA
    Hmmmm. Don't have any torx bitx. I read on TW that this would work on my '13. Crap!!!
  5. Dec 15, 2012 at 2:29 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Of course not, you have to use the Torx bitx............ use the right tool for the right hardware.
  6. Dec 15, 2012 at 2:34 PM
    Phil5393
    Phil5393 Well-Known Member
    Phil
    Long Island, New York
    TRD Sport
    Looks like you messed up the torx head on that.:eek: Like everyone else has said use a torx bit.
  7. Dec 15, 2012 at 2:45 PM
    JRFry
    Central PA
    Or not! This is the hinge on the opposite side of the tailgate. I haven't even tried this one.
  8. Dec 15, 2012 at 2:55 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    EZ-Down is overrated anyways.
    The Redline hood struts are awesome, but everyone who has installed the EZ-Down has indicated that they have not been pleased.
    It causes interference with the cable (and if you take the cable off then any weight on the tailgate stresses the strut), and it's not like the tailgate is off of a 3500 Dually and weighs a ton... The Tacoma tailgate is super lightweight and the strut really is useless fluff that just makes it more difficult to remove your tailgate if needed.
