Help removing cam bolt for LCA
Discussion in '1st Gen. Tacomas (1995-2004)' started by desert-rat, May 20, 2022.
  1. May 20, 2022 at 9:46 AM
    desert-rat
    desert-rat [OP] Well-Known Member
    somewhere in Utah
    2001 Tacoma Limited TRD SC DC
    Hi everyone. I’m replacing my lower control arms and I am stuck getting the rear cam bolt out on the driver’s side.
    To give me more room, I have removed the sway bar and unbolted the steering rack. I removed a bolt holding power steering hoses to the frame below the battery.
    The steering rack is moved as far back as I can get it without disconnecting PS lines and the LCA bolt still won’t clear. I have searched and watched videos. Others describe pulling back the inner tie rod boot, which didn’t work for me as the bolt hits the steering rack even with the boot pulled back.
    Any suggestions? I really don’t want to disconnect PS lines if it can be avoided.
  2. May 20, 2022 at 9:56 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    remove the bolts holding the rack, and push the rack up.
  3. May 20, 2022 at 9:59 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I assume you're also going to do your rack bushings?
    jammer likes this.
  4. May 20, 2022 at 10:00 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Did you make match marks on your cams to get things close on reinstall?
  5. May 20, 2022 at 10:06 AM
    eon_blue
    Azusa, CA
    yeah that bottom arrow is pointing at the long steering rack bolt, gotta pull that all way out and you should have more room to move the rack.
    if you have a diff drop installed, you might find that the steering rack bolt hits the very bottom of the front differential before it comes all the way out. I just had to grind the flange down on the rack bolt a tiny bit and was able to clear it, but it will probably depend on how much diff drop there is.
    if no diff drop then it should slide out no problem
  6. May 20, 2022 at 10:13 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Make sure the tie rod is disconnected from the knuckle. If gives you slightly more wiggle room. It's a mother trucker but that bolt can come out by only removing the rack mounting bolts and the driver side tie rod.
    desert-rat[OP] likes this.
  7. May 20, 2022 at 10:34 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Also rotate the cam to put the bolt farther away from the rack body. It will still hit the boot but it will flex enough to let the bolt by.
  8. May 20, 2022 at 10:39 AM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    Area51Runner and jammer like this.
  9. May 20, 2022 at 10:53 AM
    desert-rat
    somewhere in Utah
    Thanks guys I don’t know why I didn’t try pulling the steering rack bolt out. It was hanging up the rack from moving any more.
  10. May 20, 2022 at 1:44 PM
    desert-rat
    somewhere in Utah
    Yep!
  11. May 20, 2022 at 3:27 PM
    desert-rat
    somewhere in Utah
    I got the LCA cam bolt out but the cam sleeves are rusted in or something. 3 of the four (doing both sides) cam sleeves are stuck. I’ve tried PB Blaster and prying. Actually ended up destroying two of the sleeves because I accidentally pried the cam off the end… I’ve tried drifting them out with a 3lb sledge and pin.
    Gonna try a torch and if that doesn’t work I’ll use some carbide blades and the sawzall. :(
    Wulf likes this.
  12. May 20, 2022 at 3:54 PM
    desert-rat
    somewhere in Utah
    Torch = fail
    sawzall + several metal blades = fail
    Sawzall + carbide metal blades = win
    now it’s all fun and reassembly!
  13. May 20, 2022 at 4:04 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    For that bolt, I undid the bellows clamp and slid the bellows/boot over to the left allowing just enough more room for the bolt head to clear and slide out freely. But it sounds like you're past the dilemma now.
  14. May 20, 2022 at 6:14 PM
    desert-rat
    somewhere in Utah
    Yeah, when I did that with my boot, the bolt hit the steering rack. Oh well.
  15. Jun 23, 2022 at 12:49 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Firestone tells me my adjustment cam’s are frozen. So no front end alignment until I get them sorted. The issue with the steering rack blocking the bolts coming out (removal). Is it only a first gen issue? So second gens don’t have this issue? I just started to study the situation and source the parts.
  16. Jun 23, 2022 at 3:39 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Have the rack as far back as you can, pull the cam along with the bolt and turn the cam to the 6 o'clock position and you can pull it down at an angle and shimmy it out. That's what I did without removing the steering rack :cool:
  17. Jun 24, 2022 at 7:57 AM
    Taco!
    Taco! Well-Known Member
    98Xcab4WD
    Anybody know if a good soaking of PB blaster several days before disassembly might help with the sleeves?
    Firestone warned me after my last alignment that the cam on one side was hard to adjust and they might not be able to aligned it next time. Then they printed a quote to replace the one side for $500 (just the bolt and cams, no other bushings). I do my own wrenching, but never tackled these alignment bolts yet. I'll have to review the Timmy video.
  18. Jun 24, 2022 at 8:03 AM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Since its a long sleeve its very likely that youll have to cut it out. Just the crap nature of the design. I had to cut them all out of my FJC, but made sure to coat it all in antiseize when reassembling, so fingers crossed for next time! Once you get it all apart definitely coat them. Just doing the bolts does nothing to really help the sleeve issue.
  19. Jul 18, 2022 at 8:11 AM
    curth0man
    curth0man Well-Known Member
    Curt
    2001 Toyota Tacoma SR5 4x4
    I'm a big fan of cutting stuff like that off and throwing a new bolt in there. Usually ends up being way quicker for just a few dollars.
  20. Aug 8, 2024 at 3:49 PM
    boulderz
    boulderz Well-Known Member
    Bumping this thread for a question…When installing the rear lower control arm cam sleeves/bolts on a 1st gen, does it make sense to reinstall the bolt and sleeve facing the front? That way it would be easier to remove to lube every year or so Without having to mess with the steering rack.
