Help removing front diff
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Nov 22, 2014.
  1. Nov 22, 2014 at 6:13 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Can't get the drive shaft off. Need some suggestions/help!
  2. Nov 22, 2014 at 7:53 PM
    mrbeggins
    mrbeggins LOW.LIGHT.WIDE
    Tanner
    Airdrie Alberta
    04 Tacoma
    It's 8 bolts lol. Pretty straight forward...
  3. Nov 22, 2014 at 7:54 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    lefty loosey
  4. Nov 22, 2014 at 8:07 PM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
    Remove bolts and pit down ur purse:)
  5. Nov 23, 2014 at 6:47 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I can't get a socket seated on the four bolts that connect to the diff. I was bending my breaker bar and started to strip the bolt (used some liquid wrench well before attempting)... Ill work on it more later this week I guess just wondering if there was a trick to this.
  6. Nov 23, 2014 at 7:43 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    swivel sockets
  7. Nov 23, 2014 at 7:53 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Flame wrench Chris,,try to tighten them a bit after the heat,,then reverse to back them off for removal.
    Sounds like a box end wrench job(with helper pipe), until one end or the other is off. Then you should be able to position the drive shaft to get a socket with impact wobbly on there,,then clicking on your impact tool of choice on there. If it goes that far.
  8. Nov 23, 2014 at 4:24 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks, Ill give it a try. Could use some air tools...
  9. Nov 24, 2014 at 2:02 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    So used a 3/8" drive socket and it fit snugly over the bolt. Used a swivel adapter for the breaker and it was pretty easy after that. I was just worried as the 1/2" drive socket wasn't able to sit snug and I started stripping a bolt.
  10. Nov 24, 2014 at 10:05 PM
    CR, WA
    stock
    If you knarled those hex's up,,grab some new bolts. Those need to remain tight when you get them back on, and be trail serviceable. So don't skimp on that hardware.
    Ya,,stop and select a better socket if it is a tight fit in the work area. By better I mean the inner drive hex portion. I have some old NASA metric Blue Point impacts that I just cannot seem to sweat a bit. Extra thin wall shorties that are made out of unobtanium.:p
  11. Nov 25, 2014 at 8:49 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Bolts are good. I stopped the second they showed signs of stripping and posted here.
  12. Nov 25, 2014 at 9:51 AM
    CR, WA
    stock
    Cool.
  13. Nov 26, 2014 at 7:14 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Be sure to mark the them prior to removal the yokes that is. It can help reduce/eliminate driveline vibration
  14. Nov 26, 2014 at 7:37 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    All of my experience has been on rear drive shafts. so I'm not certain if this applies :
    Because of the trouble with getting a socket on these things, I've always used an extra-long box-end wrench. I use a regular 'shorty' to hold the bolt head, and the extra-long to position properly and apply the torque to the nut.
