help removing my lift
Discussion in 'Suspension' started by Dsmooth87, Apr 21, 2013.
  1. Apr 21, 2013 at 11:32 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    I have two questions. maybe more..
    I would like to remove my toytec 1.5 AAL an just have the tsb 4 leaf pack. What hardware do i need to make this happen. I think i threw out the old center pins etc.
    second ? I have a double cab short bed with a camper shell on it. I have 884's an billies set at 0. will this truck be sitting level once i remove the 1.5 aal? Right now it is definitely ass high a little more than an inch.
    thanks
  2. Apr 21, 2013 at 11:34 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Well by removing the AAL im guessing you are going to loose about 1.5 inches...
    also you can just cut the centering pin to the new height
  3. Apr 22, 2013 at 6:24 AM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    1 inch high in the back is pretty good. If you ever load your truck or haul a trailer you should be level. Taking that 1.5 inch AAL out will cause you to be nose high especially with a 200lb plus shell on it and 884's on the front. Even worse if you load the bed. Get some center hub to fender measurements and we'll probably be able to answer your question better based on where your truck is sitting now.
  4. Apr 22, 2013 at 1:16 PM
    gmattorano
    gmattorano Active Member
    Gino
    Colorado Springs, CO
    06 Tacoma TRD Off-Road
    Just out of curiousity, why do you want to remove the AAL?
  5. Apr 22, 2013 at 1:21 PM
    Dsmooth87
    my goal was to have the truck sit level and not have to worry about ucas an the troubles of exceeding 3inches of a lift. (from where i measured) i have about a 2 inch difference ass end being the highest on my truck with 884s and tsb aal.
  6. Apr 26, 2013 at 10:10 AM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    This may or may not help, but when I installed my 884, I was nose high without anything in the back other than TSB. You have a camper so you will definitely be nose high without 1.5 AAL.
