help removing oil filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by dud122, Feb 26, 2009.
  1. Feb 26, 2009 at 2:49 PM
    dud122
    dud122 [OP] rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    so i am changing my oil now and beig the idiot that i am i didn't check to see how hard it would be before i started...
    i successfully drained the oil but now i can't get the filter off.
    can someone tell me how i am supposed to get the filter off a 1st gen and how i am supposed to get the new one on there tight considering i can hardly get my arm up there?
    maybe i am going in the wrong way??
    any help would be VERY appreciated!!!!
  2. Feb 26, 2009 at 2:51 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I'm not familiar with the first gens, but I would venture to say that the filter wrench that fits on the top of the filter and uses a ratchet is your best bet.
  3. Feb 26, 2009 at 2:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go thru the little flap in the fender well. and you may need to use a filter wrench to get a better grip.
  4. Feb 26, 2009 at 2:52 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    i'm not by my truck now... do i need to unscrew anything to get the flap open?
  5. Feb 26, 2009 at 2:53 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    it also helps if you park the truck with the wheels turned all the way to the left, it gives you a little more room to work with
  6. Feb 26, 2009 at 2:53 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    is it ok for the truck to sit overnight with no oil in it... starting to get dark here
  7. Feb 26, 2009 at 2:53 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    no the flap is held on by little plastic rivets u can push out with your hand
  8. Feb 26, 2009 at 2:55 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    awesome... going to try that before it gets too dark... be back with results
  9. Feb 26, 2009 at 4:05 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    success!!! thanks for the help... moving the flap was key
    luckily i could unscrew the filter with my hand because the wrench i found wasn't tight enough to grip the filter
    i put in 5 qts oil and 8 (?) oz of STP oil treatment but i can't see the oil on the dipstick... maybe i need another qt. will go get that tomorrow and see but i thought the 3.4 L engine took about 5.8 qts... will check again
    thanks again for the help everyone!
  10. Feb 26, 2009 at 4:09 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    5.8 quarts equals 5 quarts and 25.6 ounces. Not sure if its the issue or me misinterpreting but I thought i would throw that out there
  11. Feb 26, 2009 at 4:11 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    the oil treatment bottle was roughly a third of the qt. oil bottle
    i guess i was over estimating how much the treatment would add
    may have been more than 8 oz too
  12. Feb 26, 2009 at 4:13 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    even with just 5 quarts it should be well up on the dipstick, you should start to see just 4 quarts on the stick. besides the obvious (leaking out as fast as you put it in or adding to your tranny fluid as in wrong dipstick) are you pushing the dipstick all the way back seated in when you're checking it? if you're sure you put 5 quarts in and the additive don't go dumping another quart in...you'll just end up draining it out later.
  13. Feb 26, 2009 at 4:27 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Owners manual for a 1997 3.4L with 4WD states 5.5 US Qt with filter change.
    If memory serves me correctly, though. I always put 6 US Qt. in.
    May have been 1/8- 1/4 Qt too much, but looked good on the stick.
    Either way, what you added should be registering on the stick. Make sure you insert the stick all the way. It's kind of finiky that last 1/2".
  14. Feb 26, 2009 at 5:01 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    Being that I'm going to be doing an oil change myself for the first time this weekend or next, it's good to hear about the trick to get the filter off. I remember reading that getting it off on the 5VZFE was a bitch. Glad to know theres an easy way to do it!
  15. Feb 26, 2009 at 5:26 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i made a mess the first few times i did an oil change on my truck with that crazy filter. Then i figured out the splash guard trick..It still makes a mess, but not as much.
    The best tip for you sir, is to take the skid plates off, or everywhere you go it looks like your truck is leaking oil for a week.
  16. Feb 27, 2009 at 3:40 PM
    tmantstud
    tmantstud High Mileage Work
    Kansas City, Kansas
    98 Tacoma high mileage
    Bed liner, Polk db651s speakers, JVC head unit, Coverking custom saddle blanket seat cover
    Have u tried priming the engine after putting the oil in it? you should have already been able to see oil. Try turning the key two clicks right and let everything circulate for about 20 seconds. then check the oil.
  17. Feb 27, 2009 at 4:51 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    this is kinda a stupid question but i have done it before did u put the plug back in after u finished draining it???
  18. Feb 27, 2009 at 4:59 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    LOL, thats what I was thinking and only because I have done it! I did that on my 97 when I was in high school, my dad just watched as I dumped 5 fresh quarts through the engine then ask if I had put the plug in. I must say I will never do that again!
  19. Feb 27, 2009 at 6:38 PM
    sonjay
    sonjay Well-Known Member
    Remember to put some clean oil on the rubber o-ring on the filter, and DO NOT over tighten, you probably already have the filter on but hand tight is more then enough. Some filters have markings at 1/4, 1/2, 3/4, half a turn past where the rubber touches should be tight enough. I've seen guys use a filter wrench to put the filter on, only to curse up and down when they try to change it later!
  20. Feb 27, 2009 at 7:08 PM
    HerNameIsLucy
    RIP Lucy.
    I had a buddy call me and say he changed his oil and now the engine wouldn't crank. Turned out he drained his tranny empty and dumped 4 quarts of new oil on top of the 4 quarts of old oil in his engine. It was so full the pistons couldn't move up and down. Pretty new Lancer too.
