help removing oil filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by dud122, Feb 26, 2009.
  1. Feb 27, 2009 at 7:19 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    WOW:eek: i bet he felt like a dumbass
  2. Feb 27, 2009 at 8:50 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    *Just a little tip when removing oil filter*
    I've heard that some people use a plastic bag around the filter to catch the oil that leaks out while your removing it. I have never done this, but i've read that it works pretty well.:thumbsup:
  3. Feb 27, 2009 at 8:55 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    He was a dumbass. Probably still is. If he's even still alive. I could tell stories of the crap he pulled but don't wanna 'jack this thread.
    On topic though...I make a mess every time I change the oil. I take a rag and wipe the spillage all over under the truck. Free oil coating rust prevention.
  4. Feb 28, 2009 at 8:06 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    So I'm going to be changing my oil for the first time tomorrow, let me make sure I got the steps right.
    Take off old filter
    put new filter on
    drain old oil
    put plug back in
    pour new oil in
    am i right, or do you drain oil first then switch out the filter? or does it really matter?
  5. Feb 28, 2009 at 8:09 PM
    dud122
    dud122 [OP] rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    i drained the oil then replaced the oil filter (don't forget to oil the gasket) since the filter will have some old oil in it then put the new oil in
  6. Feb 28, 2009 at 8:12 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    when you drain the oil first there isn't as much oil in the filter when you take it off so it doesn't make a huge mess
    i ended up putting another half qt in and it brought it up to the tright level... so it was 5.5 qts oil and the oil treatment bottle total
  7. Feb 28, 2009 at 8:17 PM
    pittim
    Pennsyltucky
    Boujee Prius
    whats this oil treatment stuff? I just planned on putting 5.5 qts of synthetic in...
    and what about the oil plug washer? Do I need to get a new one? Toyota parts is closed tomorrow...so would a place like pep boys or auto zone sell one? or should I wait until monday to do it so I can get a washer?
    and what about tightness of the drain plug? hand tight and full turn or what? I don't own a torque wrench..
  8. Feb 28, 2009 at 8:34 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    it was a bottle of STP oil treatment from adavanced auto parts
    i didn't change the oil plug washer... didn't know to
    i hand tightened the plug then did about a 1/4 turn with a wrench
  9. Mar 1, 2009 at 8:01 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    If you are using regular STP with the ZDDP anti-wear additive, it is bad for the catalytic converter in your truck. It has been removed from conventional oils for that very reason. Read the small print on the label to confirm.
  10. Mar 1, 2009 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I did this all the time on my 2000. Works very well! :)
  11. Mar 1, 2009 at 8:16 AM
    grivera
    Hanover, MD
    http://automotivemileposts.com/zddp.html
    Here is a link about it. Us in the muscle car hobby (I have a 69 Firebird with a flat tappet camshaft) have been dealing with this issue for some time. Engines with rller cams don't need zddp so new cars can do without.
  12. Mar 1, 2009 at 8:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!!!!
    I was doing an oil change on a Cat 426 Back Hoe, and I was talking with my Dad aasking him how much oil it took. He didnt know....Well, I was filling it up with some bulk oil useing an pnumatic oil pump, and chatting with him, when the oil started comming out of the top of the oil fill hole. On the top of the valve cover! :eek: It was a little much.
  13. Mar 1, 2009 at 8:51 AM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
  14. Mar 1, 2009 at 11:57 AM
    grivera
    Hanover, MD
    I wouldn't worry about it on a single oil change, but know that prolonged use may cause damage.
  15. Mar 1, 2009 at 1:45 PM
    #35
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Why would add that crap to your engine...all your doing is add a thickener to the existing oil.
  16. Mar 1, 2009 at 3:16 PM
    #36
    pittim
    Pennsyltucky
    Boujee Prius
    now i know why people hate changing the oil on these trucks :p
  17. Mar 1, 2009 at 5:03 PM
    #37
    sonjay
    sonjay Well-Known Member
    Changing the oil on 2nd gen trucks is the easiest oil change, the location of the oil filter is perfect. Pull the plug first, let it drain fully if you want and replace the plug, or while its draining pull off the filter, I use a spray can cap to catch the oil that leaks from the little nipple on the bottom of the oil cooler catch thingy. Replace drain plug, with new seal if you want, I do it maybe every 2nd or 3rd change, hand tight with a 3/8" drive ratchet will be plenty, no need to reef on it, fill the filter as much as you can (you gotta tip it a bit to get it in there so don't fill it right up) and lube the o-ring with CLEAN oil, tighten the filter hand tight, 1/2 turn past when the rubber touches, no need to crank on it either. Fill with your favorite oil, start truck, let run for 5 mins, check for leaks. Shut truck off check oil, top up if needed! It sounds like a lot, but it should only take 10-20 minutes. I forgot to mention make sure you truck is up to full temp before you drop the oil. Remember to dispose of used oil properly, most auto shops will take it for free!
    Edit, you can't fill the filter on these trucks as they go on upside down!
