Help Removing Pinstripe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EEtaco, Jul 29, 2009.
  1. Jul 29, 2009 at 3:19 PM
    EEtaco
    EEtaco [OP] Well-Known Member
    North Carolina
    09 V6 Prerunner
    So I finally got around to removing the silver pinstripe on my BSP taco, but I've run into a snag. The drivers side went flawlessly and got the left over adhesive off with some car soap. However, on the passenger side the adhesive seems 10x stronger. I've gotten about half way done because the stripe keeps breaking as I pull it off. I guess I'll try using a hair dryer or something to see if it eases the process. The left over adhesive isn't budging either, I've tried simple green, car soap, and some bug/tar remover with no luck.
    Any suggestions to removing the remaining stripe and that stubborn adhesive?
  2. Jul 29, 2009 at 3:23 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Damn!
    GOO-GONE.
  3. Jul 29, 2009 at 3:29 PM
    EEtaco
    North Carolina
    09 V6 Prerunner
  4. Jul 29, 2009 at 3:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hair dryer will work fine. for the leftover adhesive.....use some goo gone on a microfiber rag.....then wash the area/wax afterwards.
  5. Jul 29, 2009 at 4:55 PM
    Notty
    Notty Well-Known Member
    5Twenty
    2017 DCSB TRD OR
    Bilstein 5100s OME887 Deaver AAL BAMF CMC ECGS Bearing Replacement Sprint Booster
    Like said above, a hair dryer while taking off the pin stripe to heat up the glue. The best stuff I have ever used to get residual glue off is denatured alcohol. Get some at the hardware store and it works wonders. Doesn't hurt the paint at all either.
  6. Jul 29, 2009 at 6:39 PM
    wmb67
    wmb67 Well-Known Member
    Boston
    09 Dbl Cab Off Road MGM
    ^^^^ x2
    or 3m makes a good adhesive remover
  7. Jul 29, 2009 at 6:46 PM
    EEtaco
    North Carolina
    09 V6 Prerunner
    Picked up some goo-gone and I'll give it another go here in a little bit.
