Help removing rear shock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meafordmike, May 1, 2010.
  1. May 1, 2010 at 4:49 PM
    meafordmike
    meafordmike [OP] Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    Mine keep spinning, shock and nut??
    Fast reply please.
    I have to install Dakars and N182
  2. May 1, 2010 at 4:55 PM
    tacoman007
    tacoman007 ignorance is bliss,
    Josh
    san diego
    07SR5ACCESSCABDEBAGED4X4
    alpine headunit,12'' rockford fosgate sub,ipod in g-box,drop in K&N, Marine decor,5100's front/rear,uniden pc68xl,radioshack PA speaker
    hold the top with channel lock pliers, or on top there is a spot for the hex key
  3. May 1, 2010 at 4:57 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    This.
  4. May 1, 2010 at 5:19 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    X2^ on this and that
  5. May 1, 2010 at 5:26 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    5mm (i believe) hex key, you can figure out the rest.
  6. May 1, 2010 at 5:30 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    If you don't care about your old shocks, cut the boot and grab the shaft with vise grips. Then turn the nut with a socket or wrench.
  7. May 1, 2010 at 5:32 PM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    yeah that works but what about when he needs to tighten up the new one?haha
  8. May 1, 2010 at 5:33 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    the following....
  9. May 1, 2010 at 5:35 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Hex key on the shock mounts? 2nd gens are weird.
  10. May 1, 2010 at 5:36 PM
    McJosh
    Josh
    Chandler
    no, I meant that cutting the boot cover wouldn't really help on the installation of the new shock. I had this same problem when I put mine on.lol
  11. May 1, 2010 at 5:36 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    hex on the end of the shaft on the shock...
  12. May 1, 2010 at 5:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Some have a female hex on the end of the shaft, others have a "Square" end, so as to be able to grip with a wrench.
  13. May 1, 2010 at 5:40 PM
    JDMcQ
    So, instead of the double eye, like on mine. The newer Tacomas have an eye on one end and a threaded shaft on the other, much like a front shock?
  14. May 1, 2010 at 5:40 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    No need to cut the shock boot, just slide it down.
  15. May 1, 2010 at 5:41 PM
    afd23a
    The Dynamo of Dixie
    I didn't see a hex key on my stock or Bilstein HD shocks. They had a tab on the shaft to grip with a wrench. Problem was the tab broke off of my stock shocks. Cut one off and did as above for the other side. Didn't care since I was replacing them. As for the Bilstein HD's, the tab didn't break off so there wasn't a problem.
  16. May 1, 2010 at 5:41 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    right, and i meant that using a hex on the new shock would take care of everything!:thumbsup:
  17. May 1, 2010 at 5:41 PM
    afd23a
    The Dynamo of Dixie
    that would work too
  18. May 1, 2010 at 5:42 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    :thumbsup:
  19. May 1, 2010 at 5:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep.
  20. May 1, 2010 at 5:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Some have a Hex hole :
    So you can hold it still:
    While others have an end for a box wrench:
