Help Removing Rear shocks!
Discussion in 'Suspension' started by tclarke1, Dec 29, 2011.
  1. Dec 29, 2011 at 1:26 PM
    tclarke1
    tclarke1 [OP] Well-Known Member
    Tyler
    Arizona
    09 Prerunner SR5 Single Cab 2wd
    Tint, Subwoofer, De-badged, Billet Grille, URD Short Throw Shifter, MaxTrac Spindles
    Hey everyone I just got my new bilstein shocks for the rear end of my 2009 tacoma.
    I started taking off the old ones but im stuck, when I go to remove the top 14mm nut the shock just spins.. should I just use a pair of pliers to hold it or what? any tips would be great. Thanks!
  2. Dec 29, 2011 at 1:28 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    There should be a part of the stem that sticks up above the nut and has a flat spot on each side. You should be able to put a wrench on it to hold it to break the nut loose
  3. Dec 29, 2011 at 1:31 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
  4. Dec 29, 2011 at 1:32 PM
    tclarke1
    Tyler
    Arizona
    yea.. I tried that first, the quality of these stock shocks arent that great cause that was rusted and it broke right off..
  5. Dec 29, 2011 at 1:34 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Do you have an impact wrench? If not and the shocks are being replaced anyway it wont hurt anything to grab the stem with pliers or channel locks
  6. Dec 29, 2011 at 1:49 PM
    trumann33
    trumann33 New Member
    Kevin
    Columbia,Tennessee
    14 TRD OFFROAD
    well if you don't care about keeping the old shocks you can always take a cutoff wheel and cut the top nut off
  7. Dec 29, 2011 at 1:59 PM
    tclarke1
    Tyler
    Arizona
    yea thanks for all the input guys, im about to cut the nut off or cut the gaurd off the shock to grab the stem. I got the top nut loosened with pliers but not the rings are all flatened on the top from the pliers so the nut doesnt want to spin off
  8. Sep 6, 2012 at 6:50 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    I had this same problem today! I gave up! Trying again tomorrow
