Help removing tailgate handle, bolts spinning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Erik37, Aug 23, 2020.
  1. Aug 23, 2020 at 5:20 PM
    Erik37
    Erik37 [OP] Well-Known Member
    Langley, BC, Canada
    2012 DCSB TRD Sport 6spd leather
    Went to install my Pop & Lock handle and I can't get the stock handle off. I got the two 10mm bolts that hold the back up camera off but the two that hold on the actual handle just spin. I understand what the problem is, just wondering if there's a way to get the bolts out without cutting/grinding/hacking up the stock handle?
  2. Aug 23, 2020 at 6:02 PM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    You might be able to cut them and drill them out carefully, then epoxy/whatever some rivnuts in there...?? Never had that happen in a dozen or so times I've taken it off, so I'm just throwing things out, untested.
  3. Aug 23, 2020 at 6:14 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Same happened on mine simply drill the heads off and then the handle comes out.
