help replaced Factory fog light switch with Contura
Discussion in 'Lighting' started by Hoozel, Mar 23, 2013.
  1. Mar 23, 2013 at 6:37 PM
    Hoozel
    Hoozel [OP] Well-Known Member
    Ty
    Edmonton AB
    i replaced the factory Fog Light switch with a lit Contura that has the on indicator as well. I got all of the other switches to light up when switched on.... but the factory fog light switch won't light up with 'on' indicator. I didnt replace any wiring from the factory fog switch, just added what was needed for dash dimmer etc. Wired it the same as all the other switches, it just wont light up when on. Lights up fine with dash lights.
    i checked the ground its good, its not jumpered off the dash light ground feed. I can't figure out why it won't light up when flipped on.
  2. Mar 24, 2013 at 10:35 AM
    DevL
    DevL Well-Known Member
    Have you wired it up away from the dash wiring to make sure the bulb is good? It is just an incandescent indicator and might be damaged.
  3. Mar 30, 2013 at 4:49 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I plan to do the same, just ordered my switches. Keep us updated on the outcome. Do you have any pictures? How many wires on the factory switch?
  4. Mar 30, 2013 at 3:28 PM
    Hoozel
    Ty
    Edmonton AB
    I will try to get some pics. I never took any as i went. basically just cut the stock wires and put new connectors on. Ran a separate ground off of a good spot nearby, I just tapped into the green white i think that was nearby from another switch harness and ran that for all my new Contura switches so they dim with dash lights when Headlights on.
  5. Mar 30, 2013 at 3:33 PM
    Hoozel
    Ty
    Edmonton AB
    Installed
  6. Mar 30, 2013 at 3:38 PM
    Hoozel
    Ty
    Edmonton AB
    Out with the Old....
    Btw... Black Diamond Fab Grill, and BAMF bracket (very sweet design)
  7. Mar 30, 2013 at 3:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The switch indication is an LED. The switch design is not compatible with the factory fog light wiring, which is ground-true switched.
  8. Mar 30, 2013 at 4:44 PM
    Hoozel
    Ty
    Edmonton AB
    Thanks ! ya i figured it would have something to do with factory wiring. So if i wired a new ground to the switch would it still work off dash lights ? I basically just attached the factory foglight wires to this new switch....
  9. Mar 30, 2013 at 4:48 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No.
    Someone was trying to make this work a few weeks ago and he tried a few dead-ends. Nothing worked.
    The problem is, on the factory system, the hot is applied to the relay coil under the hood, and the switch provides a ground for it. The indicator light needs to have the hot applied at the switch.
    You'd have to completely abandon the factory relay and wiring and rewire it using a "standard" diagram.
  10. Mar 30, 2013 at 5:16 PM
    Hoozel
    Ty
    Edmonton AB
    Thanks for explaining that for me. makes sense now. I am no expert at 12 volt wiring so I didnt understand why it wouldn't work. I think i wont bother with a rewire, just to have the indicator light.
  11. Mar 31, 2013 at 4:25 AM
    KeithB
    Keith
    Cheshire, CT
    I will.
  12. Apr 19, 2013 at 4:48 AM
    OmegaQuest
    OmegaQuest Well-Known Member
    Maryland
    2013 Tacoma Limited Double Cab 4X4
    Oil Catch Can, Motorcycle Chock, WeatherTech Window Deflectors, Bilstein 5100, OEM 4 Leaf, Chrome Satoshi Grille, FX-R Stage III Retrofit, Color Match Head Light Mod, Front Hella 500 HID, Behind Grill Light Bar, Rear LED Bed Lights, Pop and Lock Tailgate, Chrome License Plate Covers, AFE Air Filter, Removed Secondary Air Filter, Paint engine cover (Red), ImMrYo Rear-View Mirror Lift Bracket, Center Console Organizer, ScanGauge 2, Firestone W217602407 Ride-Rite Kit, Firestone WR17602178 Air-Rite Dual Electric Air Command
    D'oh.
    I had the same issue and spent about an hour lastnight trying to figure out why the indicator light would not turn on, yet everything else seemed to work.
    Back to the drawing board I guess.
