Help! Replacing leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldblue1968chevy, Feb 21, 2014.
  1. Feb 22, 2014 at 7:39 PM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Glad to see you got it all back together. It's the unforeseen issues like that which make for long weekends!
  2. Feb 22, 2014 at 7:45 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    welcome to the world of springs....;)
  3. Feb 22, 2014 at 8:35 PM
    oldblue1968chevy
    oldblue1968chevy [OP] Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Im gonna try to build me a spring pack from my old ones 4wd ;)
    I just didnt feel comfortable trying to build a leaf spring pack.
    I thought there were shackles front and rear..lol :/
  4. Feb 22, 2014 at 8:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No worries, it's def. a learning process & sometimes a first class bitch when bolts freeze/seize , but i'm sure you learned a ton...good job adapting/overcoming the issues that plagued your install..:thumbsup:
  5. Feb 22, 2014 at 10:59 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Man, that reminds me of when I did mine several years ago. Sawsall, grinder, hacksaw, and torch, profanity, and more profanity, pb blaster, vise grips, cold chisel, punch, and finally beer. I used geaseable shackles with wheeler's 5 leafs. Had the same break line issue. All this made it easy for Toyota when they replaced the frame the next year.
    Yours looks great.
  6. Feb 22, 2014 at 11:20 PM
    Indy
    Indy Master of all I survey.
    I made a thread a few weeks ago about leafs. My advice is to buy new everything before you start and just cut it all. Life is better that way.
  7. Feb 23, 2014 at 7:39 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    It's geographics really, here in east county it's dry climate, I'm using my original hardware, my Ubolts have been on & off at least 15 times
  8. Feb 23, 2014 at 8:35 AM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    Yup yup yup agree 100%. I thought abouy geyying new bolts after reading brents thread buy didnt know what size and didnt wanna go to the dealer. And never thought the shackles would give ttouble.
  9. Feb 23, 2014 at 8:36 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Yup, that's why I bought brand new parts for everything. I honestly probably wouldn't have bought shackles if I had known my OEM ones would come off so easily, but oh well.
    I knew the fronts would have to be replaced after having worked on other parts of the truck...
  10. Feb 23, 2014 at 8:41 AM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    My front susoension came off easy. When i bought the truck you could eat off the frame super clean hardly any rust!
    Driver shackle was ez pass. Side took at least 1.5hrs
  11. Feb 23, 2014 at 8:44 AM
    PcBuilder14
    Brent
    Nor Cal
    Front suspension wasn't seized, but the sway bar was a huge pain as well as the step bars I took off.
    Shackles came off with not much force, main eye bolts didn't budge. Everything else was pretty simple.
  12. Feb 23, 2014 at 10:29 AM
    oldblue1968chevy
    Spokane WA/Viola TN
    Stock
    Should I have used the toyota torque specs to tighten the fwd leaf spring bolts? I think it was 116# ftlbs. I used grade 8 hardware bolts vs toyota bolts.
    1 side was fine the other seemed to sorta suck in the bushing from the leaf, seemed too tight?
    I'll try to get pix..
  13. Feb 23, 2014 at 12:09 PM
    PcBuilder14
    Brent
    Nor Cal
    Here ya go. Replied to your pm but figured I'd post it in here since you tend to miss things that I post :p
    Found the document from my 03 Tacoma FSM....
  14. Feb 23, 2014 at 11:15 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I'm glad to see I'm not the only one that is having a hell of a time removing my sway bar...
