HELP...rim width 4 tacoma
Discussion in 'Wheels & Tires' started by jsatch32, Jun 30, 2011.
  1. Jun 30, 2011 at 2:57 PM
    jsatch32
    jsatch32 [OP] Member
    jerry
    n.kentucky
    09 tacoma sr5 access cab 4x4
    Bilstein lift @ 2.5 setting..
    Gotta question ..... Can I fit 17x 9 rims on my 09 tacoma 4x4 access cab...I know 17 b ok but worried 9 inch may b too wide.....am I ok.?? Please say they will work cause I already bought em and they been delivered...
  2. Jun 30, 2011 at 3:00 PM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    what is your offset or backspacing?
  3. Jun 30, 2011 at 3:01 PM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    I'm running 17x9" with 4.5" back space. Seems to work for me. ATX Artillery
  4. Jun 30, 2011 at 3:02 PM
    jsatch32
    jerry
    n.kentucky
    honestly I don't know...everything is stock if that helps...
  5. Jun 30, 2011 at 3:04 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    are you running a stock 17 rim?
  6. Jun 30, 2011 at 3:06 PM
    jsatch32
    jerry
    n.kentucky
    No....16
  7. Jun 30, 2011 at 3:07 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    It would be helpful if you told us what the rims are....
  8. Jun 30, 2011 at 3:09 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    or give us a link for the rims
  9. Jun 30, 2011 at 3:09 PM
    BlueTaco07
    Cody
    Looking
    You cant run a 17 rim on a 16 tire?
  10. Jun 30, 2011 at 3:10 PM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    This site will help give you an idea of how much backspacing you'll get.
    http://www.autolounge.net/calculators/tirespacing.html
    A 9" rim with 0 offset puts you exactly at 5" of backspacing. I think you are safe up to about 5.75" backspacing. Which is about a +19 offset. After that, you'll probably have rub issues.
  11. Jun 30, 2011 at 3:12 PM
    jsatch32
    jerry
    n.kentucky
    They r raceline raptor....17x9....
  12. Jun 30, 2011 at 3:19 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Whats the specific part number?
    981-79060 17x9 6x5.5 0mm offset 5.0 backspace will work better then,
    981-79065 17x9 6x135mm +6mm offset 5.25 backspacing
  13. Jun 30, 2011 at 3:22 PM
    jsatch32
    jerry
    n.kentucky
    Part no.982-79060......17x9.....pcd 6x5.5....hub 107.95
  14. Jun 30, 2011 at 3:23 PM
    97yota4wd
    Eric
    Mesa, AZ
    i think you should be okay
  15. Jun 30, 2011 at 3:24 PM
    Dark Knight
    Jeff
    NC/SC
    may rub a little with 285's
  16. Jun 30, 2011 at 3:26 PM
    jsatch32
    jerry
    n.kentucky
    Was thinkin bout 265/70/17 Terra grapplers...b ok.??
  17. Jun 30, 2011 at 6:13 PM
    jsatch32
    jerry
    n.kentucky
    So ill b ok to order 275/75/17 on 17x9 rim .....sorry, I forgot to mention I got the 5100 bilsteins for all 4's...
