HELP! Rubbing with 33s, 04 Tacoma
Discussion in 'New Members' started by Luke Moody, Jan 4, 2014.
  1. Jan 4, 2014 at 5:19 PM
    Luke Moody
    Luke Moody [OP] Member
    SC
    04 Toyota Tacoma
    3in lift
    I have an 04 Tacoma with a 3in Suspension lift with 33x12.5x17 I rub really bad when I turn and I was wondering how can I fix that, I really miss the freedom off being able to turn all the way I believe my rims have a +12 offset if that helps, would wheel spacers help?
  2. Jan 4, 2014 at 5:21 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Get a pair of wire snips and trim bud! It's common so don't sweat it ;)
  3. Jan 4, 2014 at 5:21 PM
    LukeBo4x4
    LukeBo4x4 The more people I meet, the more I like my dogs.
    luke
    Big Island,Virginia
    03 TRD ext cab
    OME 882s, wheelers 5 leaf pack w/aal, ARB front bumper, 305/70/16 nitto mud grapplers,pro comp 7069s, Grey wire mod.
    Sawzall
  4. Jan 4, 2014 at 5:24 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Cut the plastic on the inner fender and pound the shit out of the pinch weld there. I did that and still rub a little
  5. Jan 4, 2014 at 5:30 PM
    Luke Moody
    SC
    04 Toyota Tacoma
    3in lift
    they rub on the frame a bit and mainly on the metal piece above the shock theres not even enough space to fit my hand between week and shock I done cut all the where it scrubed on finder
  6. Jan 4, 2014 at 5:44 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Rubbing on the upper control arm? I'd get some spacers then
  7. Jan 4, 2014 at 5:47 PM
    Luke Moody
    SC
    04 Toyota Tacoma
    3in lift
    I guess that's what its called I could get pictures but what size do you recommend, do you think spacers will fix it so when I turn I will be back to normal?
  8. Jan 4, 2014 at 5:51 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    3/4" hubcentric Bora spacers, you don't want to go too far out or it will rub in a different spot, also, if you have it realigned and get the caster to 2.5, the rubbing will disappear or be minimized to barely rubbing and you won't have to hammer the krap out of the pinch weld...
    setting the caster to 2.5 or more sets the wheel forward a bit more in the fender well and solves most, if not all of your rubbing problems....
  9. Jan 4, 2014 at 6:33 PM
    Luke Moody
    SC
    04 Toyota Tacoma
    3in lift
    how much would that run me about>?
  10. Jan 4, 2014 at 6:35 PM
    frankakashane
    frankakashane Well-Known Member
    Frank
    San Diego, California
    06 White 4x4 TRD SR5 O/R Pack
    Icon extended travel shocks front~Icon resi extended travel rear shocks~Alcan rear springs~total chaos UCAs~Wheelers super bumps front and rear~Diff drop~steel brake lines~Alpine single din stereo~blacked out emblems~front 1.25" spidertrax wheel spacers~carrier bearing drop~TRD cat back exhaust
    i was rubbing with my 265/70/R17s (31.6") even after I got a small lift on my truck. Got some spidertrax 1.25" spaces in the front and fixed my problem.
  11. Jan 4, 2014 at 6:46 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    "how much would that run me about>?"
    a good shop that knows what they are doing, and depending whether you get a lifetime alignment or a one time alignment, probably a low of $50 and upwards $80 plus...
    the Bora 3/4" spacers are about $218 including shipping ($47.50 each plus shipping and maybe tax)....you could save and get only two spacers for the front, but it will look a bit weird compared to the rears....
  12. Jan 4, 2014 at 9:11 PM
    frankakashane
    Frank
    i thought it would look weird only having them in the front also, but it actually doesn't. Since its an IFS set up, it just made the front look normal after my lift (which was probably about 2.5" or so).
  13. Jan 4, 2014 at 9:23 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    12.5" is a bit wide to use without use of spacers and/or less backspacing and 1" body lift. Trimming the wheel well is not an option for most people, but clear out that pinch weld area real good.
