help runing wire under truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cristofxr50, Sep 12, 2024.
  1. Sep 12, 2024 at 11:46 AM
    cristofxr50
    cristofxr50 [OP] New Member
    i have a 2023 tacoma trd off road and i want to install a wolfbox mirror dash cam but i want to run the back camera under the truck and put it on the license plate
  2. Sep 12, 2024 at 11:49 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Under the carpet through the grommet and follow the wire harness on the left side of truck that goes to gas tank.
  3. Sep 12, 2024 at 11:52 AM
    cristofxr50
    ok thanks alot!
  4. Sep 12, 2024 at 11:54 AM
    Tacomike18
    J
    No problem
  5. Sep 14, 2024 at 3:38 PM
    FabioBT17
    FabioBT17 Member
    2017 Dbl Cab TRD Off-Rd - Manual
    I am running wiring for the tailgate lock and trying to follow the harness along the driver’s side. I am stuck trying to get the wires through along the gas tank and can’t figure out how to get the wires through. What am i missing. The install videos seem to skip this part. Any help?
  6. Sep 14, 2024 at 3:41 PM
    Tacomike18
    J
    The wire harness goes on top of the gas tank on the driver side of the truck frame. It’s a tight squeeze but if your truck is lifted you have no problem going in the left rear wheel well.
  7. Sep 14, 2024 at 4:04 PM
    FabioBT17
    FabioBT17 Member
    No lift for me. Left wheel well does not have much space. Biggest problem is the front of the wheel well at the body mount. Right there is almost no space.
  8. Sep 15, 2024 at 5:26 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    Get a length of stiff wire like bailing wire or maybe an old coat hanger and tape your wiring to it. Feed the stiff wire through first and use it to fish the harness through. The stiff stuff will be easier to guide through the tight spaces and you can kind of bend it to the right shape for the needed curves.
    Ngneer and po35042 like this.
  9. Sep 15, 2024 at 6:57 AM
    D500
    D500 Well-Known Member
    David
    SE Georgia
    If I remember right, the OEM tailgate lock runs along the passenger side, and plugs into the door lock circuit behind the passenger kick panel. If you have something besides the OEM, it might be different.
    Korby, Taco_mike73 and Buggin112 like this.
  10. Sep 16, 2024 at 6:22 AM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    The tailgate lock cable also has a length of of metal insulation to help protect it from the heat of the exhaust on the passenger side
    Taco_mike73 likes this.
  11. Sep 16, 2024 at 7:21 AM
    D500
    David
    SE Georgia
    Also has some metal zip ties to go in that area.
    AZPhys13 likes this.
  12. Sep 16, 2024 at 2:09 PM
    mississippicelery
    mississippicelery Active Member
    Can confirm. Just did this last week.
  13. Sep 16, 2024 at 2:20 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Tocamo likes this.
  14. Sep 16, 2024 at 3:19 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    the directions for the OEM tailgate lock should tell ypu to run it on the passenger side. there is a few you tube videos on it. I had a lot of trouble with mine as it sad to zip tie it to a cable that all ready was in the right frame rail, but no cable on mine. the cable they tell you to use is for the AC outlet in the bed. If you have an SR5 or anything but a TRD you don't have the outlet and no cable. you just have to find places to zip tie too along the frame. I eventually got it.
  15. Sep 17, 2024 at 2:48 PM
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    It's a bit of a PITA, but you can use a fiberglass wire fishing pole or one of the reels from HFT, just take your time and be paintent. It's a pita but not impossible. Removing your spare might give you better visibility.
  16. Sep 17, 2024 at 2:48 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Some are intended to be ran on the driver's side. The ones for the passenger side have fiberglass/foil thermal insulation so that they're not damaged from the radiant exhaust heat.
  17. Sep 17, 2024 at 4:55 PM
    Taco_Ventures
    Taco_Ventures Well-Known Member
    N
    SL, UT
    23 Taco OR DCLB
    Look up the instructions for the r4t tailgate lock. That is the best way to run your camera wire too. Passenger side up through a grommet under the front pass seat.
  18. Sep 17, 2024 at 9:43 PM
    Taco_mike73
    York, PA
    The Oem kit does indeed have a portion of the cable that has that insulation. Toyota engineed the kit well enough.
  19. Oct 6, 2024 at 12:35 PM
    FabioBT17
    FabioBT17 Member
    I had the pop and lock kit designed for driver’s side. I ran the wires up the passenger side and modded the kit to connect to passenger side door wires. Used wire tap connecters on the green and red wires.
  20. Oct 7, 2024 at 5:29 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I installed one of these locks and ran the wire up the passenger side along the rail, found some other wiring to use as a guide attached a couple tire wraps up under there, ran it up to the grommet under the seat no problem just took my time. I did not run on top of the gas tank, No need.
