HELP: Runs like crap once Battery gets Reconnected
Discussion in '1st Gen. Tacomas (1995-2004)' started by mmcmahan2206, Sep 11, 2013.
  1. Sep 11, 2013 at 10:59 AM
    mmcmahan2206
    mmcmahan2206 [OP] Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    So I've had this happen to me twice now, the first time I thought it was just a coincidence. I wired up my Hella 500 HIDs, and in doing so, I disconnected my battery. Everything with the install went very well, but when I hooked the battery back up, my truck ran like the timing was retarded or a vacuum line wasn't hooked up (coughing, sputtering, couldn't increase RPMs without it wanting to almost die). So I went thru all the basics (checked hoses, checked fuses) and it all looked good. Then I decided to clean my MAF sensor, and that seemed to help. I could now drive the truck, but it seemed to have loss of power (I wan't able to accelerate as fast). Eventually, the truck got back to normal and I just assumed the truck re-mapped it's fuel/air or something...? :notsure: Anyway... I just installed some audio components to the rig this past weekend, and when I hooked the battery back up (wouldn't ya know it) the truck ran like crap again! SOOO, I checked my fuses and hoses/lines again, and ended up cleaning my MAF sensor again to get the truck drivable! Is this just coincidental??? Or is my truck going into some mode of relearning air/fuel or something???
    Any feedback would be greatly appreciated, as I am at a loss of what to check/do next. Thanks!
    - Matt
  2. Sep 13, 2013 at 12:30 PM
    mmcmahan2206
    McCall, Idaho
    Wow... no replies after 85+ views..? This must be a rare issue. Looks like I'm SOL. :(
    Anyway, thought I'd update the situation here. So each day since the incident, the truck has gradually ran better and better. The day after, I did a MIL scan and had a "Fuel too lean" code (which is always on anyway), and a pending code of "Engine Misfire." I cleared the codes and scanned again the next day, to only find the normal lean fuel code. I feel as tho it hasn't reached its full potential yet, and I really hope that it does! But this seems to me to be a prolonged re-learn for my truck... Any thoughts? What do you guys think???
  3. Sep 13, 2013 at 12:33 PM
    Nirvana
    Nirvana Tesla Auto - Non union and proud
    Kris
    Bay Area, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, 285/70R16 KM2s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Being that it got better after driving for awhile both times, that's more than likely your answer.
  4. Sep 13, 2013 at 12:38 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    After each time I reconnect my battery, I have to cycle the key on and let the pump prime up, switch back off then start the truck. If I don't, then it does sputter and die. Try just cycling the key.
  5. Sep 13, 2013 at 12:40 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    The Ecu's in these truck are self learning. You've gotta drive a handful of miles and it will get better with time.
  6. Sep 13, 2013 at 12:48 PM
    mmcmahan2206
    McCall, Idaho
    Right on, that's what I'm hoping for! Thanks for the feedback!
    Thank you so much for that info! I was not aware of that at all! I will def try that next go around! ;) Thanks!
    I've driven about 40 miles since... shouldn't it be "re-learned" by now?? Or do I need to put some more on it?
  7. Sep 13, 2013 at 1:07 PM
    cyberbyte
    cyberbyte MR2/Tacoma
    Jim
    Michigan
    06 SR5 Tacoma 4dr
    Yak Rack, SS Running Boards, Pioneer Sound System
    I have the tow package on my 06 dbl cab SR5 which comes with the 130 amp alternator, and a 27 battery ( upgraded to 29 ) you may want to check the voltage.. I can run anything ( so far :) w/o dimming problems.. looking to upgrade the amp with new kickers.. I have never seen my lights dim, but there is a 30amp fuse ( engine bay ) that may blow if grounds are faulted.. just for the record, I have led's on my boat trailer as well.
  8. Sep 13, 2013 at 1:18 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    Mine is 03, but works the same, usually mine will start to run normal after about 5 minutes or so. I usually just start it and let it run on its own till the RPM's start to climb to normal idle and it smoothes out. By the way you always want to disconnect the ground first that way there is no chance of frying anything else.
  9. Sep 13, 2013 at 1:35 PM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    It sounds as if you have a larger, underlying problem.
    While yes, your truck will "re-learn" the proper mapping to achieve proper running conditions, the CEL should tell you something.
    If your truck is attempting to learn some very LARGE changes compared to stock, it will take correspondingly longer.
    Are there any other mods on your truck that would change it drastically?
    When was the last time the O2 sensors were changed? They can become sluggish but still not trigger a CEL.
    Furthermore, how does it behave normally? Are there any hot start issues.. any quirks... splutters... noises or otherwise abnormal running conditions that you've experienced?
  10. Sep 13, 2013 at 5:19 PM
    DWreck
    Derek
    Las Vegas, NV
    Usually around 75 miles to reset
  11. Sep 14, 2013 at 6:27 AM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Shouldn't run that bad after just resetting the ecu.. Sounds like you got a lean problem, like he said start with the o2's
  12. Sep 16, 2013 at 3:49 PM
    mmcmahan2206
    McCall, Idaho
    I haven't replaced the O2 sensors yet, and not sure when/if they were replaced. I bought the truck w/ 87K on it, and now she has 130K.
    Other MODs include K&N air filter w/ Downey intake, Airaid throttle body spacer, Flowmaster exhaust... I think that should be all that could possibly effect the learn time.
    The truck normally has no issues and runs like a champ... until I have to unplug my battery for somethin. :mad:
    Okay, thanks! I just got back from a 200+ trip from this last weekend, and my truck seems to be back to norm (great accel, runs smooth, idles smooth)! So I'm guessing that my re-learn time is considerably longer than if it were stock. Thanks for your help!
    I've been told that replacing the O2's might not even stop the lean code just due to the fact that all my mods may have it thinking that it needs race fuel or something crazy like that! I use premium gasoline always, and the truck seems to run perfect, but will always throw a lean code (even after 10 mins of clearing code). So how important is it in MY situation to replace O2s?
    Thanks for the feedback BTW!
  13. Sep 24, 2013 at 8:22 AM
    mmcmahan2206
    McCall, Idaho
    Just updating the thread.
    My truck continues to run great and back to normal now! I'll definitely have to try cycling the key next time I disconnect my battery and see if that makes the problem not happen. I'll keep ya'll informed. Thanks!
