HELP: Ruptured CV Boots
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HMA, Oct 10, 2011.
  1. Oct 10, 2011 at 6:21 AM
    HMA
    HMA [OP] Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Tacoma 4x4 Surveying Machine
    '10 TRD 4X4. I noticed grease on my fender wells yesterday. I felt around the outer CV Boots and both of them have apparent punctures. I use this truck for Land Surveying and have been working around corn & cotton fields lately. I'm pretty sure corn and or cotton stalks are the culprit. Questions:
    -Are the boots replaceable? If so, what level of effort is required? If not,, should I run as is and wait for the joints to wear out, then replace the axles.
    -After I resolve the issue, are there any sort of guards made to keep this from happening again? I had the same problem on a 4 wheeler. I bought some guards from "Ricochet" and they seem to work well.
  2. Oct 10, 2011 at 12:41 PM
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island, Hawaii
    10 Access Cab TRD OR 5AT 4x4; 08 Regular Cab 5MT 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    If they haven't been torn for too long, take the CV's in to a shop to be repacked with grease and rebooted. I've never done the job myself but I heard it can get pretty messy if you do it yourself.
    Never heard of people running guards for CV's on Tacos, so can't help you there.
  3. Oct 10, 2011 at 3:07 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
  4. Oct 10, 2011 at 3:12 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I feel your pain!
    If you don't think you can do it yourself have it taken to a shop. Havent really heard of CV guards because of IFS articulation
  5. Oct 10, 2011 at 8:16 PM
    toytaco970
    toytaco970 Well-Known Member
    avon/vail, co
    05 trd offroad 4x4
    Front: Icon IVD coated extended travel coilovers Rear: 5125's with AAL and 1" block. Front sway bar removed. Brute Force Fab bumpers AllPro stuff: UCAs , front skid plate, sliders, rear u-bolt flip kit, e-locker guard Kenwood/Garmin single DIN DVD-NAV system, amp and sub. V1 radar, Foglight anytime mod,
    Boot kits run around $40, you can get the entire axle assembly for a little more from a auto parts store. Rebooting is a messy pain in the ass but not hard to do. I recently replaced both my axles with EMPI axle assemblies. $100 each on autopartswarehouse, no core. Kept the oem axles and will reboot them in the future for spares. If you think this will be an ongoing issue due to your job/truck use, having two sets might be your best bet
  6. Oct 11, 2011 at 4:00 AM
    HMA
    Hal
    Bainbridge, Ga
    Thanks for the help. I read where several guys had Toyota replace them under warranty. I'm going to give this a try, but I don't expect it to work. I'll probably end up replacing the axles with aftermarket ones. I still want some sort of guards or something to keep it from happening again. Any help on this is appreciated.
  7. Oct 11, 2011 at 4:09 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Rebooting them is cheap and not too difficult. I would do that. Aftermarket CV axles are nowhere close in quality to the OEM Toyota axles.
  8. Oct 11, 2011 at 9:35 AM
    danimal92sport
    danimal92sport Well-Known Member
    dcab, 4WD, TRD O/R
    I agree on both points here. I have replaced a couple of CV boots in the past and it's a filthy nasty job, but relatively quick and easy.
    I've also read lots of horror stories regarding aftermarket CV axles on many Toyota forums. With such a critical component, why take the risk when your axles likely just need new boots and grease?
    Dan
  9. Oct 11, 2011 at 9:37 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    As shady as it sounds, I would at least try to play the dumb card at the dealer.
    Fink
