Help separating steering stops from lower balljoint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by azchris, Apr 19, 2020.
  1. Apr 19, 2020 at 12:20 PM
    azchris
    azchris [OP] Well-Known Member
    Prescott, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    From my searching I apparently may be the only person in the world to have difficulty with this particular step of a lower control arm swap. Shock and cam bolts came right out in two seconds with no fuss, but I cannot get the steering stop to budge. I've sprayed it down with PB blaster and beat the hell out of it with a sledgehammer and it hasn't moved. Any tricks to this that don't involve a beefy press?
  2. Apr 19, 2020 at 12:40 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Pickle fork, hit the steering stop with a hammer on the side, or there are little pullers you can rent that would knock press it off.
    Here is said puller
    Asianguywithatruk and Larzzzz like this.
  3. Apr 19, 2020 at 12:43 PM
    little squirt
    little squirt 808 ALLDAY!!
    808 ALLDAY!!
    ^^^^ this or a pickle fork ball joint splitter...usually easier to knock that ball joint loose when a-arm is still installed on the truck....maybe bolt up back real quick, just snug, then knock that joint loose
    dk_crew and ovrlndkull like this.
  4. Apr 19, 2020 at 12:44 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Good point about it still being on the truck that way you're not chasing it around trying to get it separated.
  5. Apr 19, 2020 at 12:55 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    You need a bigger hammer.
    The one that @ovrlndkull pictured will work too if it fits. Crank it down then give that bolt a good whack
    Tango Bravo likes this.
  6. Apr 19, 2020 at 1:10 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I remove it with the LCA attached to the vehicle. With that front corner on a jack stand, work out the nut half way out; use jack to lift up the LCA about an inch; use hammer or air hammer to hit side of the bracket until it breaks free (weight of the car helps push it out). With it off the car, I'd apply some heat from a torch on the bracket (not the bj) and hit the end of the bj or use a bj fork until it pops out.
  7. Apr 19, 2020 at 1:17 PM
    azchris
    Prescott, AZ
    I put the LCA back on and jacked the truck up off the ball joint stud and beat on the bracket with a 3lb hammer from the front side - got nowhere. Gonna pull it off again and try the torch next...
  8. Apr 19, 2020 at 1:37 PM
    Chuy
    Lakeside, CA
    Silver Taco
    You also push up on the lca about an inch with the jack - this puts some pressure on the bj to separate. You can also apply heat with it still installed. I've separated the bj twice this way, but without applying heat. The OEM bj's and another time to replace the shitty bj's on a Dorman lca.
  9. Apr 19, 2020 at 1:43 PM
    azchris
    Prescott, AZ
    Just ended up making a nice little balljoint fire and it popped right out. I'll try getting the other side off while it's still on the truck... Thanks everyone for the tips!
    Naveronski likes this.
  10. Apr 19, 2020 at 1:49 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I haven't met any parts that could withstand a 20lb steel sledgehammer. That baby 3lb can barely bend cotter pins lol :D just kidding, glad you got it out!
  11. Apr 19, 2020 at 1:54 PM
    azchris
    Prescott, AZ
    Definitely picking up a BFH next time I'm at the hardware store :D
    will.i.was[QUOTED] likes this.
  12. Apr 19, 2020 at 2:05 PM
    little squirt
    808 ALLDAY!!
    at least you have a nice torch! I've been getting by with a little map gas trigger bottle.
  13. Apr 19, 2020 at 3:27 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I'm stealing this pic. It really shows how I feel about repairs some times.
    desertrunner24 likes this.
