HELP! Sheared Rear Differential stud
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carolinataco, Oct 18, 2015.
  1. Oct 18, 2015 at 2:11 PM
    carolinataco
    carolinataco [OP] Well-Known Member
    NC
    2019 TRD OR, VF Tuned, URD Power Extractors, U-spec exhaust, Meso stuff
    I noticed a slow leak coming from my rear differential so i started to investigate and it looks like i need a new gasket, BUT before ordering i decided to check the nuts around the diff for tightness.. The very first bolt/stud i checked(and area of most leakage) snapped as soon as i applied pressure.
    How can i remove the sheared stud(nothing to grip with pliers or weld to)?
    Where can i order a new stud from?
    When i do change the gasket should i use the Toyota gasket or just go with silicone?
    Will it be safe to drive until i have time and the parts to fix it?(100miles per day)
  2. Oct 18, 2015 at 3:18 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  3. Oct 18, 2015 at 5:46 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You probably going have to remove third member completely off. Once you do this the rest of the stud should be sticking out on the inside of the housing. Since it was submerged with oil, probably it will take only fingers to unscrew it.
  4. Oct 19, 2015 at 10:43 AM
    carolinataco
    NC
  5. Oct 19, 2015 at 10:59 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I think that this is what I would go for. Unless you are going to try to replace just that bolt and see if the oil leak stops. I have been thinking about this as well since I looked at my front diff and it looks like one of the bolt heads was sheared off from the factory. It isn't leaking so I am not worried about it, but if it starts once the warranty is out that is what I will do to handle it.
    As far as driving it goes, as long as the leak is slow you should go get some cheap 80-90 from walmart and keep it topped off until you get around to changing the gasket. If it is leaking fast enough to drain the diff on your long drive I would not drive it until it is fixed.
  6. Oct 19, 2015 at 2:32 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    If you are going to try to fix it without pulling the third member, see if you can get a "Reverse Drill Bit" Make sure you center punch the broken stud and then use the reverse drill bit. If the stud is loose it might come out just from drilling the pilot hole (just don't drill all the way through the stud). It the drill bit doesn't back it out then try the extractor. If you are pulling the third then simply try some vice grips on the piece that is hopefully sticking out of the axle housing after you remove the 3rd. Also, a bit of grease on the bit and around the stud hole will help catch the metal shavings as you drill.
  7. Oct 20, 2015 at 5:25 AM
    carolinataco
    NC
    Thanks for the replyies, I'm going to take the 3rd member off this weekend and replace all the studs(except the 2 by the locker) with class 10.9 button bolts. Ive seen a few ppl do this on other forms and it seems to work really well and hopefully I'll never have this problem again!
  8. Jun 19, 2018 at 8:03 PM
    Timbospice
    Timbospice New Member
    What size studs did you buy one of mine broke too? 8mm or 10mm?
    b_r_o likes this.
  9. Jun 19, 2018 at 9:55 PM
    peteyfresh
    peteyfresh Well-Known Member
    Pete
    13 Taco DCLB, 04 4Runner, 97 Jeep ZJ, 86 VW GLI
    The torque for those nuts is only 18 ft/lbs if i remember right.
    Helpful tip: wet the new gasket with water before you try to fit it over the studs. It will seem a tiny bit too small and will tear if you don't. It's just a thin paper gasket and getting it wet will help it stretch enough to fit around all the studs.
  10. Jun 19, 2018 at 11:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    10 mil, probably
