Help! Sirius radio HARDWIRING
Discussion in 'Audio & Video' started by wtbthree, May 8, 2010.
  1. May 8, 2010 at 3:04 PM
    wtbthree
    wtbthree [OP] Well-Known Member
    Okay, I pulled my Sirius radio setup out of my '05 AC before trading it in for a '10 DC. The unit is a SC-FM1 tuner.
    To power the FM modulator box and display, three wires (shown below) are spliced into existing wires coming from the stereo.
    Upon removing the unit from my old truck, I wrote down which of the stereo wires (by color and size) were used. However, in my new truck, the wiring is very different coming out of the 6-disc changer. I dont know which wires to tap into.
    The instructions say the following:
    (Yellow) = to vehicle battery +12V
    (Red) to switched ignition +12V
    (Black) = to ground -12V
    I think this is from the AUX input, could it be that these
    red, black, and yellow wires are indeed the ones I need?
    I dont know, as this stereo wiring certainly doesn't follow conventional wiring codes
    And I dont have any kind of voltage tester or DC light.
    ANYONE KNOW WHAT WIRES I NEED TO USE??
    ...and I cant find the specs for the radio anywhere
    any help would be greatly appreciated
  2. May 8, 2010 at 3:27 PM
    wtbthree
  3. May 8, 2010 at 3:59 PM
    ChiefThickums
    ChiefThickums Scrub
    Tyson
    San Luis Obispo
    Bad Ass Gen I
    6 in' Trailmaster, 33x12.50's, TRD supercharged, flowmaster, K&N. Used abused and put away wet.
    I got a Gen 1 and my cigerette lighters are switched. the ground you can pull off anywhere you can stick a spade under a chasis bolt... that just leaves you needing to find a 12V constant so you just have to find sumn that is on all the time or has a memory. Or take the guess work out and buy a 5 dollar bulb poker typer meter from radio shack and start poken around in your wire loom.
  4. May 8, 2010 at 4:15 PM
    ChiefThickums
    ChiefThickums Scrub
    Tyson
    San Luis Obispo
    Bad Ass Gen I
    from a quick search I found that the wiring harnesses for toyota radios haven't changed since 1987... if that is true then your wiring should be the same as mine... i make no garuntees tho. G'luck
    Car Radio Battery Constant 12v+ Wire: Blue/Yellow
    Car Radio Accessory Switched 12v+ Wire: Gray
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: Green
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: 6 1/2″
    Car Audio Front Speakers Location: Doors
    Left Front Speaker Positive Wire (+): Pink
    Left Front Speaker Negative Wire (-): Purple
    Right Front Speaker Positive Wire (+): Green
    Right Front Speaker Negative Wire (-): Blue
    Car Audio Rear Speakers Size: 6 1/2″
    Car Audio Rear Speakers Location: Rear Corners
    Left Rear Speaker Positive Wire (+): Black
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Red
    Right Rear Speaker Negative Wire (-): White
  5. May 8, 2010 at 4:35 PM
    wtbthree
    Well, as for the brown ground wire, there are 2.
    each the exact same color, but different sizes. I dont know if either one could be used
    as for the constant 12v+ wire, I cannot find one in any cluster that's Blue/Yellow
    there is one very small gray wire though....hmm
  6. May 8, 2010 at 5:28 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    you should have two more plugs...one will have the power wires. 4 plugs total into the back of the radio. the two you show pictures off seem to be the wires to the speakers. You should have one plug for the steering wheel controls/aux input and another that carries the power.
    Edit....Or maybe you should have 3 harnesses total...i can't remember. But the harness only attaches by 2 harnesses, leaving one for the aux. I have 4 plugs on the back of my oem unit but i can't remember if they were all used.
    Ok...the white plug is the one you need to be using. the little wires in the corner carry the power it seems. The ground is the brown wire beside the purple wire, blue is your constant, and grey is your switched...like the man above said.
    wiring placement is shown here with a nice diagram.
    http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
    scroll down for the current year.
  7. May 8, 2010 at 5:45 PM
    wtbthree
    Yep, here are the other two plugs. There are four total.
    Not sure I understand you...
    "....But the harness only attaches by 2 harnesses"
  8. May 8, 2010 at 5:57 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Ok go back to the original 2 harness you had...you need to only use the larger one. you are looking for the little wires. Go to the link i posted and match up the pin configuration as to your wire color. From what i can see it should be.
    brown beside purple = ground
    blue = 12+ Constant
    Grey beside blue = 12+ switched
  9. May 8, 2010 at 6:00 PM
    wtbthree
    I think ive got it.
    I have another kenwood head unit that I had in my old '05 truck. I still have the wiring harness with it that adapts to the plugs coming out of the dash. all the wires on the harness are labled and are the correct color. i can plug the harness into the dash and match the wires.
    idk if that makes sense, or if it needs to. I figured it out
  10. May 8, 2010 at 6:03 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    makes sense, your doing what i said....only in real life!
  11. May 8, 2010 at 6:04 PM
    wtbthree
    thanks guys
