Help! Soldering aluminum wires
Discussion in 'Audio & Video' started by Caligula, Jul 20, 2015.
  1. Jul 20, 2015 at 3:19 PM
    Caligula
    Caligula [OP] Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Can someone help me out, I can get the solder to tin on the terminals im using, but it avoids even touching the copper clad aluminum wires im using in my audio build.
    Im using 60/40 lead solder, rosin flux, ive tried a butane torch as well as a soldering iron.
    Different solder, different flux?
  2. Jul 20, 2015 at 3:23 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    May be a dumb question, but why are you using aluminum wires? If they are copper clad, wouldn't the solder just stick right to the copper anyways?
  3. Jul 20, 2015 at 3:24 PM
    Caligula
    Los Angeles, CA
    Its not sticking to the copper. Copper clad aluminum is what im working with, so thats why im asking.
  4. Jul 20, 2015 at 3:26 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    When using wires with any mix of wire I always use an Aluminum Soldering Flux.......
  5. Jul 20, 2015 at 3:28 PM
    Caligula
    Los Angeles, CA
    This is different from Rosin flux?
  6. Jul 20, 2015 at 3:35 PM
    Jocoma
    Jocoma Well-Known Member
    Jo-mama
    Olympia,WA
    08 Prerunner SR5 Rugged Trail
    Home made satochi trd grill BFG AT 265 75 16 Dipped badges TRD stub antenna More to follow : spindle lift,Halo lights, Kicker sound sytem ,Slotted rotors TRD Seat covers When the cash starts flowing
  7. Jul 20, 2015 at 3:39 PM
    IPNPULZ
    going to be fun!
    I guess it is somewhat I solder a lot of Aluminum with copper in HVAC and Refrigeration and use a lot of stuff the is 45% Silver or higher and solder a lot of terminals to wire without any issues....
  8. Jul 20, 2015 at 3:41 PM
    IPNPULZ
    going to be fun!
  9. Jul 20, 2015 at 3:41 PM
    Zollars
    Zollars Well-Known Member
    Eagle River, AK
    2009 TRD Sport 4x4
    Suspension: 5100 Billstein Front Shocks Rear AAL 3" lift Engine Bay/Engine: Under-Hood LED lighting Hood QuickLift Elite Hood Struts - Redline Tuning Exterior Additions/Mods: Front Steel Skid plate Front Bumper Light Bar - NFab Bed Cap System: Steal Bedside and Tailgate Caps - KBVoodoo Fabrications 2x US Flag Vinyl Decals Under Mirrors - Far North By Design Exterior Lighting/Electrical: Retrofit Headlights - Ambiguous Fog Light Relay Mod (Fogs On With High Beams) - Thanks To Ostrichsak Depo Taillights 50" 4D Curved Trac Performance LED Light Bar - SLX Motorsports 4x Spot Fog Lights on NFab bar Full Exterior LED Bulb Swap - CSJumper LEDs Interior Additions/mods: CVRV Mirror Riser - BirdDawg Industries Pioneer 8100NEX Head unit Interior 6 Switch Panel - IggyCorp Interior Lighting/Electrical: Backlit 4x4 Switch Mod - RCBS204 Otrattw Switches On IggyCorp Panel For Accessories Dome Light on With Open Door Mod
    I always use an aluminum Flux like IPNPULZ said. Someone told me to years ago and I have since without issues
  10. Jul 20, 2015 at 3:45 PM
    IPNPULZ
    going to be fun!
    This stuff has a lot to do with temperatures of each metal if you get copper to hot it melts away same with Aluminum....
  11. Jul 20, 2015 at 4:02 PM
    Caligula
    Los Angeles, CA
    Cant seem to find anyplace in Los Angeles that sells this stuff.
  12. Jul 20, 2015 at 4:03 PM
    IPNPULZ
    going to be fun!
    California it's properly illegal!!
  13. Jul 20, 2015 at 4:42 PM
    Jocoma
    Jo-mama
    Olympia,WA
    Best thing to do is to remove all the old solder from the terminal sand it or use a wire brush then coat it with flux.
    Then coat the wire with flux heat it up and add the solder. If you can heat up the terminal instead of the wire to add the solder.
  14. Jul 20, 2015 at 9:17 PM
    Caligula
    Los Angeles, CA
    We were trying to make your mama illegal here but the demand was too high.
  15. Jul 20, 2015 at 9:19 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    how hot is your iron?
  16. Jul 20, 2015 at 9:25 PM
    Caligula
    Los Angeles, CA
  17. Jul 21, 2015 at 5:11 AM
    IPNPULZ
    going to be fun!
    So this is your Cranial Rectosis reflex response without conscious thought?
  18. Jul 21, 2015 at 2:45 PM
    Caligula
    Los Angeles, CA
    Ive tried both a torch and an iron. The solder is flowing fine, its just gong around and avoiding the wires. Ive already tried scraping the wires with a brass brush and using lots of Rosin flux.
    The flux is just burning off and leaving a slimey mess. I dont get what im doing wrong, ive never had this issue with all copper wires.
  19. Jul 21, 2015 at 9:42 PM
    Caligula
    Los Angeles, CA
    Im using 60/40 tin/lead solder. I havnt seen solder with that much silver avaliable, even so i dont think it would be that affordable. Should i be using traditional lead free solder suck as 97sn/3ag?
    This stuff is advertised as aluminum solder, its the only one i can find labeled as such. its looks to be regular silver solder. Any thoughts?
    http://www.amazon.com/gp/product/B00DC3102Y
  20. Jul 22, 2015 at 4:43 AM
    IPNPULZ
    going to be fun!
    If I was having so much issue soldering I would use wire tap connectors or crimp connectors and be done with it!!!
    Is this some import wire?
    As long as you are preparing the wire correctly you should not be having these issues soldering is not by any means rocket science....
