Help! Some Jerk punched a hole in my gas tank!
Discussion in 'Technical Chat' started by RideFast, Sep 22, 2012.
  1. Sep 22, 2012 at 6:31 PM
    RideFast
    RideFast [OP] on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    While I was mountain biking someone decided to use what looks like a screw driver to puncture a hole in my tank. I just filled my tank up too! :mad:
    I have seen some products out there to repair plastic tanks. Do you guys have any experience using plastic gas tank repair kits?
    060EC9D7-65E9-4226-BC91-A68B6750F033-194_fd20b4227ad0c38088b3f7040687ac60986bd85e.jpg
  2. Sep 24, 2012 at 5:51 AM
    shemp
    shemp Well-Known Member
    Wow, that's low.
    I would say that the tank needs to be removed for this repair, and thoroughly cleared of all remaining fuel and vapor.
    I would think that the best way to repair this would be to weld it. You will need a filler plastic of the same type. I would be inclined to use a sheet metal plate on the inside to help maintain the form during the welding process, warm up the vicinity of the damage with a high temperature heat gun, I would avoid using a flame on it to prevent igniting the plastic, but you will want to liquify the gash in the tank and drip in molten plastic to fill the void. You can lay it on nice and thick for a ways around the gash to reinforce the area.
    I would avoid using any kind of glue on it, as I'm sure most "repair" kits are. When you're dealing with a bond between dissimilar materials, you are almost guaranteed a long term problem with it, and eventual leaking, plus it won't be possible to weld it later when its been contaminated by glue.
    In my opinion, you can either weld it, or replace it.
  3. Sep 24, 2012 at 5:59 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    Now THAT was an educated post. Sadly, mine is not :(
    I would do my best to fix it, in the way Shemp described, if funds are an issue. I'm sure a gas tank is not cheap.
  4. Sep 24, 2012 at 6:28 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For quick and easy, I'd try to locate one at a local salvage yard and do a swap out unless you have the time/knowledge to plastic weld as mentioned above. Personally, I can not weld plastic so I'd be looking for a replacement in a salvage yard or online parts dealer.
    And I agree, that's one of the lowest things I've seen done in a while... Some people just plain suck!
  5. Sep 24, 2012 at 6:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    There are several instant gas tank repair epoxies out there that are more than effective. And it would only take about 5 minutes.
  6. Sep 24, 2012 at 6:49 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    BINGO! They actually work too.
    So no more siphoning, just punch a hole and take what you need, absolutely terrible.
  7. Sep 24, 2012 at 7:30 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    There is a "marine" type clay putty that comes in a small tube which is used to repair Poly gas tanks on boats. You can actually use it underwater and it hardens to a JB weld type seal. Some of our fisherman swear by that stuff and my local ACE hardware carries it.
    Sorry i don't have info, but just to let you know there are easy options for you out there.
  8. Sep 24, 2012 at 2:35 PM
    RideFast
    Jesse
    Tacoma
    Thanks guys for the great responses! I talked to a well trusted mechanic today. He has no interest in this repair as he is a DOE mechanic. He told me they will plastic weld or use a patch kit as a last option on the road to get their trucks to a location where a new tank can be installed. The reason is because tanks expand and contract with the temperature, there will always be a weak spot at the repair site and it could fail. I put my family in my truck and the more I think about it, I don't think this is something I want failing with my kids and wife in the truck.
    If I fix myself it might last forever, but there is a chance it will fail?
  9. Sep 24, 2012 at 2:43 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Dam that sucks
  10. Sep 24, 2012 at 2:43 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    If you can get your hands on B 1/2 sealant it works great. B 1/2 is used to seal wing tanks of aircraft. I used it to seal a fuel tank on my dirt bike that was beaten quite a bit and it never failed or leaked. Its good stuff. Its also called Proseal.
  11. Sep 24, 2012 at 2:56 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    You can get a plug and put it in with a router. It spins the plug so fast, friction heats the plastic and the plug melts in to the tank. Good as new.
  12. Sep 27, 2012 at 6:29 AM
    Romo7493
    Romo7493 Active Member
    Media, PA
    2016 TRD OR DCSB Black
    Did you call your insurance company? Wondering what they would have to say about this. Probably nothing good but still wondering.
  13. Sep 27, 2012 at 9:45 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    A patch or plug is a good thing to use until you can get another tank. Not replacing it is like buying cheapo brakes. You could, but why settle?
  14. Sep 27, 2012 at 11:47 AM
    shemp
    A proper weld job can actually be better than new.
  15. Sep 28, 2012 at 6:19 AM
    photonashville
    photonashville Well-Known Member
    2006 Silver 4x4 long bed with Leer
  16. Sep 28, 2012 at 6:34 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i almost caught some fools taking all the fuel from our fleet...they ran and left electric pumps, drills, etc..
    i was gonna clobber them!! anyways, one guy got his personal truck drilled..he tried every sealant the store had..one by one, they all failed. he took it in, finally and got a junkyard tank.
    good luck..some people suck.
  17. Sep 28, 2012 at 6:37 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    On the news the other day they were talking about how they are drilling nowadays since they can't siphon. They had pictures of how they routed the hose and everything.... I'd rather have them siphon!
  18. Sep 28, 2012 at 6:46 AM
    CVYota
    CVYota Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    something else to worry about, beside stealing catalytic converters? Great.
    time to armor up
  19. Sep 28, 2012 at 6:47 AM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    We were driving down the road with my buddies dad, and long story short we hit some rebar in the road. His dad ended up sticking some soap in the hole temporarily because the fuel would not eat away at it. It was by no mean a long term fix but got us back to town safely.
  20. Sep 28, 2012 at 6:58 AM
    shemp
    Excellent point. Douchebags will be douchebags. If you make it more difficult for them to commit their douchebaggery, they'll just cause more damage in the process.
    Like you, I'd much rather the tank be siphoned than the tank be destroyed. Either way, you lose your fuel. In the former, in fact, there even remains the high chance that they don't drain it all the way, so you can probably even drive it to the nearest gas station.
    I once had a property get broken into. Douchebags kicked in the door. Of course, the heavy steel dead bolt firmly held together, resulting in both the door and the door frame being destroyed. In retrospect, a plastic latch would have been much better since it would hold up to everything less than being kicked in, but would save both the door and the frame if it was kicked in. They get in either way. Might as well limit the damage when they do.
