Help. Something splashed on my truck.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Superdavert, Sep 19, 2017.
  1. Sep 19, 2017 at 8:25 PM
    #61
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    What ever it is that got on there, the exhaust heat helped it bond on the paint.
  2. Sep 19, 2017 at 8:32 PM
    #62
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    Nobody has said anything about using your fingers. I have detailed cars for awhile and sometimes just using your fingers to rub that stuff off works best. If that doesn't work, take it to a good detail shop. Promise they will get if off.
  3. Sep 19, 2017 at 9:17 PM
    #63
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I didn't read anything but the first post but um wax and grease remover aka paint prep aka acetone aka paint thinner. Hell WD40
  4. Sep 20, 2017 at 8:40 AM
    #64
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    I think it is a lot less common to find it with a decent amount of acetone in it now.. that's why i suggested it.
  5. Sep 20, 2017 at 9:05 AM
    #65
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  6. Sep 20, 2017 at 9:38 AM
    #66
    wheeliest
    Json
    TMPE AZ
  7. Sep 20, 2017 at 10:17 AM
    #67
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    That's just ethyl acetate [​IMG] with some pink dye. While it is an organic solvent it won't get you high and it definitely won't dissolve that stain.
    It smells kinda nice actually.
  8. Sep 20, 2017 at 10:45 AM
    #68
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    WD40 works on everything..
  9. Sep 20, 2017 at 10:47 AM
    #69
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    m600, gunmetal rinse, spit.
  10. Sep 20, 2017 at 11:00 AM
    #70
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    Xylene diluted in distilled water (5-7%)
    Rub on- wipe off- rinse. It says it's safe on clear coat and will not remove it or paint. Then I would clearbra or clear vinyl over the affected area after it's cleaned and dried.
  11. Sep 20, 2017 at 11:05 AM
    #71
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    If none of the solvents work try rubbing it gently with polishing compound. I had a bunch of spray on sunblock bonded to my Taco's paint and of the three things I tried (wax and clay bar didn't do jack) it was the only effective solution. I was super paranoid about ruining the paint so I started from the least aggressive method and moved up the ladder. If polishing compound didn't work rubbing compound would have been the next thing I tried. Good luck getting that crud off the truck.
  12. Sep 20, 2017 at 11:22 AM
    #72
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    First step is obviously to wash the truck.
    You've clayed then obviously its something a little more pervasive than dirt.
    If you have a DA polisher I would use an orange pad and a heavy polishing compound. Hit it with that after claying again and see what it can do.
    If you don't have a polisher then maybe hit it by hand with a cutting compound and a microfiber applicator pad.
    This should be able to buff off with patients and the right tools.
    I would move this over to the detailing section. You will get answers from people who actually know how to properly care fir paint rather than a bunch of people who act like weekend detailers telling you to put chemicals on that will degrade your paint or tell you to scrape the hell out of it with your fingernails.
    You don't want to do anything but attempt to buff it off if clay doesn't work. Anything else is likely just going to damage your paint. Plus buffing this off will take minimal effort and be cheap no sense wasting your time trying to make it come off chemically.
    Harry and scottalot like this.
  13. Sep 20, 2017 at 11:40 AM
    #73
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Really?
    Here's a little secret....That aint soot my man.
    medic2230 likes this.
  14. Sep 20, 2017 at 11:47 AM
    #74
    medic2230
    Murph
    Bama! Roll Tide
    Must be that evil 10% ethanol. :rolleyes:
    bluezzy[QUOTED] likes this.
  15. Sep 20, 2017 at 11:47 AM
    #75
    medic2230
    Murph
    Bama! Roll Tide
    Lick it?
    bluezzy likes this.
  16. Sep 20, 2017 at 11:52 AM
    #76
    la0d0g
    running for the hills
    For crawling not hauling
    Don't forget to ask the nurses and doctors for help too!
    PackCon[QUOTED] likes this.
  17. Sep 20, 2017 at 11:53 AM
    #77
    medic2230
    Murph
    Bama! Roll Tide
    May need a tech or two also.
    la0d0g[QUOTED] likes this.
  18. Sep 20, 2017 at 12:23 PM
    #78
    JOHNNYPICKLES
    JOHNNYPICKLES Well-Known Member
    Chicago
    2019 White Double TRD OR
    Diesel fuel and a rag will take it right off.
  19. Sep 20, 2017 at 12:26 PM
    #79
    godzilla67
    godzilla67 Well-Known Member
    Portland,Oregon
    2013 Tacoma Regular cab Base Model 2WD
    If no one suggested this yet. Try Mr. Clean magic eraser it is an awesome product it may take that right off.
  20. Sep 20, 2017 at 12:29 PM
    #80
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    2015 DCLB Sport
    6112’s/5160’s Snugtop Rebel NTG’s 265/70/17
    I've used lighter fluid before with success.
