Help spec out King's for a 6" procomp lift
Discussion in 'Suspension' started by dman597, Jul 17, 2012.
  1. Jul 17, 2012 at 7:06 AM
    dman597
    dman597 [OP] Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    I just purchased a new 2012 4.0 4wd, double cab, shortbed, w/ tow package.
    The dealer is installing a 6" procompstage 1 lift. I want to upgrade the shocks with kings in front and back. I do tow a boat and this is my daily driver, so i was thinking maybe some adjustable shocks.
    Thing is i don't know that spring rate/ length etc etc to order for the lifted application. I do not Wheel to much and i drive on the beach alot to surf fish.(the newbs on the beach rut the hell out of it)
    Any advise?
  2. Jul 17, 2012 at 7:09 AM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    icon make a shock for the procomp 6inch lifts, unless you have a mind set on kings i would just go with the icons
  3. Jul 17, 2012 at 7:12 AM
    zacksblacktaco
    west virginia
    06 trd sport access
  4. Jul 17, 2012 at 7:17 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    If you're only installing a stage 1 kit, I'd look into a full Leaf Replacement first before getting new shocks & Coilovers. This will make it ride much better then having a block out back. :cool:
  5. Jul 17, 2012 at 7:19 AM
    dman597
    Doug
    maryland
    sry i for got to mention the dealer has ordered new leaf pack but not sure yet exactly what they ordered.
  6. Jul 17, 2012 at 7:23 AM
    dman597
    Doug
    maryland
    I like how the kings are adjustable with there valving.
  7. Jul 17, 2012 at 7:40 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Get ahold of Sonny at Downsouth Motorsports and ask him. I highly doubt the stealership is getting you a leaf pack as a lift. I bet it's still a block lift. If you are towing I would suggest not just a front coilover but a full lift leaf pack not the crap block and stock leafs.
    They have it for lifted applications: http://downsouthmotorsports.com/i-1...current-toyota-tacoma-4wd-2wd-pre-runner.html
    Do you have a Lifted '05-'10 Toyota Tacoma with a Fabtech or Pro Comp kit and you want to replace the front coilover shocks and rear shocks (Optional) with a Good Quality Shock? Look no further,These front coilover shocks can be made to bolt directly into a lifted Truck..Contact us for details or Click the Box Below
