Help spinning nut in frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LJrubi, Oct 20, 2024.
  1. Oct 20, 2024 at 10:02 AM
    LJrubi
    LJrubi [OP] Well-Known Member
    Dan
    North West NJ
    2015 MGM TRD Sport DCSB
    Was changing out my rusty crusty gas tank straps and one of the bolts came halfway out and then started spinning. Of course I can't access or see what's going on but I'm assuming a nut welded to the frame broke loose. If I cut the bolt, what are my options for a new bolt for the strap? Would a rivnut work?
  2. Oct 20, 2024 at 10:05 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    I've had rivnuts on 2 of the bolts for my gas tank skid for the last few years with no complaints. Only thing I'll say is that I had to use a dremel to clean up what remained of the weld from the weld nut so the rivnut could compress properly. Also painted after dremel but before rivnut to try to prevent future rust. Took a little bit of time to get right but it has held.
    TnShooter likes this.
  3. Oct 20, 2024 at 12:51 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    I ran into the same problem when removing the tank to replace my fuel sending unit. Check out this thread.
