Help Starter going out??
Discussion in '1st Gen. Tacomas (1995-2004)' started by .Trdtaco315., Jul 21, 2010.
  1. Jul 21, 2010 at 8:22 PM
    .Trdtaco315.
    .Trdtaco315. [OP] Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    so i went to move my truck and she didnt wanna start, it had power but i just heard clicking. i got it to start tho. i should replace it ASAP?
    how much is the repair? thanks for the help
  2. Jul 21, 2010 at 8:59 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    if you turn the key and it clicks, release the key and try it again..First signs of no start is a battery. Have your battery checked, and it its good its probably the starter. Depending on what motor you have, it shouldnt take you anymore then 2 hours or so, if you take your time. Probably looking at around $100ish for a new starter.
  3. Jul 21, 2010 at 9:17 PM
    .Trdtaco315.
    Will
    Santa ana
    just replaced the battery haha. i got a 3.4l
    guess ill get a new starter, easy to do myself?
  4. Jul 21, 2010 at 9:18 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Rather simple!
  5. Jul 21, 2010 at 9:19 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    I had the same thing and it ended up being the wire that goes from the battery to the starter, it was corroded bad. Learned this after I bought the brand new starter and put it in....
  6. Jul 21, 2010 at 9:29 PM
    .Trdtaco315.
    Will
    Santa ana
    ill definatly check that out, thanks man.
  7. Jul 21, 2010 at 9:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Nippondenso starters are well known for worn out solenoid contacts. If you can get the starter part number off of the starter, you should be able to go down to the dealer and buy only the contacts. Save some money if you can do it yourself.
  8. Jul 21, 2010 at 9:32 PM
    Firefighter160
    Josh
    Eastern VA
    05 DCSB Offroad
    These starters are also very easy to take off and clean up all the contacts, did that on my 4runner and worked like a charm.... Just get a wire brush and sand paper.
  9. Jul 22, 2010 at 5:10 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    IMHO, If you spend the time to take it apart, replace the contacts. All you do by cleaning them is buy time/get home.
    I would replace the whole solenoid, if offered. Heat breaks down the little windings on the solenoid faster than the big ones on the starter.
  10. Jul 22, 2010 at 7:36 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    exactly..Your in there already, why not just replace it. I dont need to rebuild a starter on my truck, and then have it conk out in the middle of no where.
  11. Jul 22, 2010 at 7:38 PM
    .Trdtaco315.
    Will
    Santa ana
    hey thats for all the info guys, but i think ill just get a new one and do it myself. im pretty sure i can do it.
  12. Jul 22, 2010 at 7:43 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    just a word of advice, take the passanger side wheel off, and remove that bracket that holds the hard brake lines to the inside of the frame. Easily can squeek the starter out then.
