help starting problems in the mornings
Discussion in '1st Gen. Tacomas (1995-2004)' started by jff, Mar 25, 2014.
  1. Mar 25, 2014 at 1:11 PM
    jff
    jff [OP] Member
    JEFF
    Guyana South America
    02 toyota tacoma SR5
    bilstein struts 4600 front,Skyjacker (8000) nitro Rear shocks + hellwig helper spring 1,000,Dura Int. Rotors,bendix Pads,dual exhaust ,k & N air and oil filters,Moog ball joints: Upper & Lower ,Moog outer & inner Tie Rod End ,side roller bars/step.tyres 285/75/r16,Rear Diff. Breather Installed.
    hey everyone ,im new to tacoma world ,i owned a 02 tacoma and with 142000 miles and having starting problems only in the mornings after using it in the day ,i had changed the battery and still getting same results ,during the day and nights the taco runs like new but as soon as i park it and go to start in the morning its giving a sluggish & very low idle start i have to step on the pedal to rev it then it starts and after that no problem ,how can i fix this ???
  2. Mar 25, 2014 at 2:15 PM
    gearcruncher
    Canadain bumper technician
    When was last tune up ?
    Fuel filter , spark plugs etc .
    Have you cleaned the throttle body , idle air control motor etc ?
    What have you done to try and alleviate the issue ?
  3. Mar 25, 2014 at 2:24 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    When was the last time the truck had a tune up?
  4. Mar 25, 2014 at 4:40 PM
    jff
    jff [OP] Member
    JEFF
    i had jus changed the batteries because i taught that was the problem,i wanted to go get it scan tomorrow, no tune-ups was done in like 6 to 8 months now . i had the throttle body in mind but didnt get around to it .
    after my first start in the morning the truck is fine for the day even when i turn off for like 2 hrs and turn on back its fine .
  5. Mar 25, 2014 at 4:51 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Is the alternator good?
    Are you battery terminals tight & clean?
    Could be just about anything...... Hell, every once in a while, my 07 is sluggish to start.
    Something I've read on this forum..... Try turning your key to the ON position and let it sit there for a couple seconds, then turn to start. I'm not exactly sure how effective this is, but I understand what/why .... it's supposed to prime the fuel pump.
    Worth giving it a try.....
  6. Mar 25, 2014 at 4:59 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm going to guess Coolant Temperature Sensor but I could be wrong.
  7. Mar 25, 2014 at 5:06 PM
    jff
    jff [OP] Member
    JEFF
    battery terminals tight and clean thankz ,i had tried the turning of the keys to the on position and let it sit there the turn but same thing happens ,but when i press the pedal while starting it starts perfect
