Help Stereo wiring problem!
Discussion in 'Audio & Video' started by Codeyota, Oct 10, 2011.
  1. Oct 10, 2011 at 8:15 AM
    Codeyota
    Codeyota [OP] Active Member
    Cody
    Flagstaff AZ- Grants Pass, OR
    03 dblCab TRD 4x4
    I am not using a quick wiring harness. I have power running to my deck the backlights are on and when I press buttons it makes noises. For some reason the screen is blank besides the backround color. Also I inserted a disk and cannot get it out. Any hep would be greatly appreciated!!
  2. Oct 10, 2011 at 8:57 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Sounds like a power or ground problem. There are generally two power wires, one that maintains the clock and settings, another to actually power the unit. The typical aftermarket unit uses yellow and red for these two functions.
    Do you have them hooked up to the Tacoma wires that provide this same function? Do you have the unit properly grounded?
  3. Oct 10, 2011 at 9:26 PM
    Linelock4
    Linelock4 Member
    Jared
    New Hampshire
    04 Extra-cab V6 5-speed 4x4 Limited TRD
    Spectra intake and Air-Raid throttle body spacer.
    First off what is the make and model of the deck?
  4. Oct 11, 2011 at 7:45 AM
    Codeyota
    Cody
    03 dblCab TRD 4x4
    Hey guys! Thank you for replying. I actually figured it out I had a suspicion it was the deck itself even granted it was brand new. I took it back and got the same deck, plugged it in, in the parking lot and bingo. Everything was wired correctly it was just a dud. Thanks again guys!
  5. Oct 11, 2011 at 7:46 AM
    Codeyota
    Cody
    03 dblCab TRD 4x4
    And lbridges thank you for your service, I appreciate it much!
  6. Oct 11, 2011 at 9:03 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Good deal, that was gonna be my first suggestion :D
  7. Oct 11, 2011 at 10:09 AM
    lbridges
    Lee
    Jonesville, FL
    2022 SR Access Cab
    None yet
    Thanks for thanking me, but it sounds like I didn't do jack, your return action was the cure - all's well that ends well.
    Edit: brian (below) straightened me out. Either way, no need for thanks.
  8. Oct 11, 2011 at 10:25 AM
    brian
    Elizabeth City, NC
    he was thankin your for your military service :)
