HELP!!! Stranded STUCK GEAR SHIFTER
Discussion in 'Recovery' started by TacoTruckinTX, May 19, 2018.
  1. May 19, 2018 at 5:37 AM
    TacoTruckinTX
    TacoTruckinTX [OP] Member
    TJ
    Port Arthur, TX
    2015 dbl cab long bed V6 4.0L 4x4
    Bug guard, need bars, Snugtop camper shell, Yakima integrated rack.
    Auto trans. Parked with pass side slightly inclined on hill. ABS light on and I can't shift out of park. Tried restarting. Tried pushing from front to relieve brake pressure. I'm stuck in Austin.
  2. May 19, 2018 at 5:41 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Did you try the little gear release button to the left of the shifter?
    TacoTruckinTX[OP] and jberry813 like this.
  3. May 19, 2018 at 5:43 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You might have a blown fuse. Check the fuse box under the dash. Look for tail lights or break light fuse.
  4. May 19, 2018 at 5:45 AM
    SH7mi
    SH7mi Elite Performance Tune PA MD DE NJ
    Kevin
    West Grove, Pa.
    2021 Tacoma DCLB OR Black Performance Elite Tune
    AE manifold spacer Bed lights Seat Jackers Blackvue Dashcam Elite Performance Tuned Fumoto Oil Pan Valve
    THIS
  5. May 19, 2018 at 5:46 AM
    Chris24
    Greensboro, NC
    I assume u wiggled the steering wheel too?
    TacoTruckinTX[OP] likes this.
  6. May 19, 2018 at 11:50 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Post in the Texas forum on here and someone will probably be close to help you out if need-be.
  7. May 19, 2018 at 11:51 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
  8. May 19, 2018 at 4:41 PM
    koditten
    Kirk
    Central Michigan
    Well? What ended up being the issue?
    Chris24 likes this.
  9. May 19, 2018 at 7:44 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Dirty Harry and Chris24 like this.
  10. May 22, 2018 at 4:08 PM
    TacoTruckinTX
    TJ
    Port Arthur, TX
    I removed plastic cap next to gear shifter and used screwdriver to manually release out of park. Taking it to dealer this week. I'm on duty now so I can't yet. Will look at fuse box under dash. Stay tuned
    TXpro4X4 likes this.
  11. May 22, 2018 at 4:10 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    No need to take the truck to a dealer for a simple fuse
  12. May 22, 2018 at 4:35 PM
    koditten
    Kirk
    Central Michigan
    Still need to figure what caused the fuse to blow, if the issue is bad fuse for tail lights.
    Im not to proud to admit I popped mine screwing with the stereo.
  13. May 22, 2018 at 8:57 PM
    TacoTruckinTX
    TJ
    Port Arthur, TX
    Haven't determined if its a fuse yet. The warning lights on the dash are ABS and the Anti Skid icon....permanently on when engine running. Owners manual says to take to dealer immediately on page 504 of owners manual with shift lever unable to be shifted from park.....Ill know more tomorrow. The issue is not exterior/tail lights. Its not being able to shift from park even with brake pressed in. I have to use the over ride button each time.
  14. May 22, 2018 at 9:01 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yes, under warranty assumed here.
    Do not take No or it a normal thing for an answer!!!!aagain!!!!
    Good luck
  15. May 30, 2018 at 7:35 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Any updates? What was the issue?
  16. May 30, 2018 at 7:40 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    Chock the wheels with emergency brake on.
    Start the vehicle. Go underneath it and disconnect the transmission linkage. Shift it into Drive manually.
