Help!!!!! Strange like Jerk when Coming to complete Stop
Discussion in 'Technical Chat' started by tunerperformance, Mar 4, 2010.
  1. Mar 4, 2010 at 4:50 PM
    tunerperformance
    tunerperformance [OP] Member
    08 tacom xsp
    Hey guys and gals i have an 08 tacoma prerunner xsp with the 4.0 and auto trans when i come to a complete stop and i let my foot off the brake just a little to say inch forward i get like a little jerk that comes from the rear end almost like someone rearended me im thinking its in the rear end like gear lash or something along those line but the shop forman at my local toyota dealer told me it was normal i really havent noticed it till as of late any suggestions or anyone elsw have this same problem thanks.
  2. Mar 4, 2010 at 6:02 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    search for "axle wrap". not sure about 2nd gens but (for my truck) its either lack of grease on the drive shaft or bad/worn out leafs or a combination of both.
  3. Mar 4, 2010 at 6:04 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Google Axle wrap.... common on toyotas
  4. Mar 4, 2010 at 6:08 PM
    04prerunner
    04prerunner Well-Known Member
    kyle
    tampa, Fl
    2004 prerunner
    stock
    definately axle wrap! I experience the same thing in my 1st gen
    check your leaf pack. how flat is it?
  5. Mar 4, 2010 at 6:14 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    A aal will cure that problem...or get the rear tsb done.
  6. Mar 6, 2010 at 2:37 PM
    tunerperformance
    08 tacom xsp
    I have had the rear leaf spring tsb done is there another rear tsb that I'm unaware of and what exactly does the axle wrap do
  7. Mar 6, 2010 at 3:10 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
