Help! Strange noise on 1998 Tacoma 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by Killer, Mar 9, 2012.
  1. Mar 9, 2012 at 5:49 AM
    Killer
    Killer [OP] Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    My son's truck started making this noise about a week ago.
    Before I started changing parts, I wanted to see if anyone here had any suggestions on what the noise is?
    This noise was filmed with the AC fan off and in an idling. The pitch doesn't change when the steering wheel is turned.
    Also, any step by step guide into how to fix it would be appreciated.
    Thanks for your help and suggestions!
    http://youtu.be/j7fDS4qQ6s8
  2. Mar 9, 2012 at 5:55 AM
    Killer
    Mobile, Al.
    http://youtu.be/KWL_yeRHdJI
    <iframe width="640" height="480" src="http://www.youtube.com/embed/KWL_yeRHdJI" frameborder="0" allowfullscreen></iframe>
  3. Mar 9, 2012 at 6:02 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Does the noise get louder with higher RPM's?
  4. Mar 9, 2012 at 6:04 AM
    Killer
    Mobile, Al.
    Yes it gets louder with more RPMs.
  5. Mar 9, 2012 at 6:05 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    Harmonic balancer on crank could be going bad?? How many miles on this 1998?
  6. Mar 9, 2012 at 6:07 AM
    Killer
    Mobile, Al.
    This 1998 Tacoma now has 33,000 miles.
  7. Mar 9, 2012 at 6:09 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It could be a number of things. It's hard to tell from a video. If it were mine, I'd remove all the belts and check the pulleys and idlers. Check the water pump too. Then if there was nothing wrong with those, I'd look at the timing idlers. When was the timing belt last changed?
  8. Mar 9, 2012 at 6:09 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    33K? Wow, garage kept?
  9. Mar 9, 2012 at 6:14 AM
    Killer
    Mobile, Al.
    I bought it from a retired man that kept the Tacoma in a barn at his hunting camp. It had 19,000 miles on it when I bought it a 1.5 years ago. It had never been washed or cleaned. I think he greased it, changed oil and put gas in it.
    Other than that, I don't think he touched anything else on the Tacoma. So no timing belt has been changed, no water pump was changed or anything else.
  10. Mar 9, 2012 at 6:15 AM
    hillbillynwv
    Fairmont, WV
    33,000 or 133,000 miles?......My wife's 1998 4Runner with the same motor has 203,0000 miles!..........that's amazing if it is a 98 with only 33K.
  11. Mar 9, 2012 at 6:15 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It just started doing this?
  12. Mar 9, 2012 at 6:19 AM
    Killer
    Mobile, Al.
    Yes it has 33,000 miles. Not 133,000 miles.
    My son told me about it about a week ago. The last time I was under the hood of the Tacoma was around the first of January 2012. He had me put in a high power amplifiers in for Christmas so I had to upgrade the alternator. The Tacoma sounded fine then.
  13. Mar 9, 2012 at 8:29 AM
    Killer
    Mobile, Al.
  14. Mar 9, 2012 at 9:12 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Its the sound system. Possible bad ground. Alternator or head unit.
  15. Mar 9, 2012 at 9:31 AM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    kinda sounds like mine, front main bearing (crank). if under load the noise get louder once i get to speed limit noise quite down.
  16. Mar 9, 2012 at 9:41 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Sounds like an idler or bearing. Either the crank, water pump idler, or one of the free idlers. If it starts squealing then its most likely the water pump idler which means change the water pump. If it starts to smell like burnt rubber or any smoke comes out then the idler is REALLY done. The bearing will be completely done and your timing belt will start to rub and burn
    Happened to me, but that was at +200,000 miles.
    Best way to proceed is to pull off your top rad hose and pull off the crank cover(the thing that says 3400 FOUR CAM 24) Then you can see your timing belt and idlers.
    What?! :confused:
  17. Mar 9, 2012 at 10:11 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    This is what the water pump idler looked like when i took the cover off. Notice its at an angle and poping off
  18. Mar 9, 2012 at 4:22 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    First place i would start would be the A/C idler bearing. That one is super easy to check and replace.
  19. Mar 10, 2012 at 9:10 AM
    Trifenix
    so cal
    99 LT 5 lug Taco
    I just thought it could be electrical related since it was just installed. Since low mileage didnt think it would be bearing related but i guess that depends on condition of the truck.
  20. Mar 10, 2012 at 5:50 PM
    Killer
    Mobile, Al.
    I just got my truck back from the Toyota dealership. If anyone ever has this same problem, it was the AC tensioner pulley. The 3.4L had 36,869 miles.
    While it was there I had them replace the timing belt, water pump, belts, hoses and fuel rail service. It was expensive but, I don't want my son breaking down out of town.
    They also said my truck has never had a recall on the frame or ball joints.
