help strange sound in steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by 20toy01, Jun 1, 2014.
  1. Jun 1, 2014 at 5:57 PM
    20toy01
    20toy01 [OP] Member
    paul
    tennessee
    1998 Toyota 4runner
    31-10.5-15 falken ats. Yakima roof rack. Soon to come bilstien adjustable front and rear and a basket roof rack.
    Needing help my truck is making a squeaking popping noise on passenger front wheel. Maybe the ball joint not sure .
  2. Jun 1, 2014 at 6:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Could be a lower ball joint, if so DO NOT WAIT LONG to change it or I promise you'll be very very sorry & if it lets go at speed you'll be changing your shorts too...
  3. Jun 1, 2014 at 7:29 PM
    20toy01
    20toy01 [OP] Member
    paul
    tennessee
    1998 Toyota 4runner
    I've heard various prices on parts and labor and it sounds outrageous would it be easy to fix on my own because the part is cheap but the labor is just ass rape. Thanks
  4. Jun 1, 2014 at 7:42 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Easy to change. I've done this twice recently and takes about an hour. Just make sure you have the right tools, like a pitman arm puller to pop the tie rod and LBJ out. You could try the hammer method but didn't work for me and I've read others that started the job and then realized they need the pitman arm puller. You don't have to buy it either, just rent from a parts store.
    The popping sound could be a couple different things. I suggest raising up the front suspension and checking for play in the LBJ, tie rod, wheel bearings. When you check the LBJ for play make sure to use the pry bar method
    As for parts and labor... Oem is best and recommended. If you go aftermarket try
    Raybestos ProGrade. If you want to pay for labor then your probably looking at at least an hours worth of labor which at most shops is probably gonna run $85+
  5. Jun 2, 2014 at 5:55 AM
    20toy01
    20toy01 [OP] Member
    paul
    tennessee
    1998 Toyota 4runner
    Thanks a lot that was very helpful. Hopefully I can do it on my own.
