HELP! Strange vibration under slow acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by klim83, Nov 10, 2011.
  1. Nov 10, 2011 at 12:34 PM
    klim83
    klim83 [OP] Member
    Louisiana
    06 tacoma prerunner double cab
    3" lift , Blacked out taillights , custom rims , 8000K HID conversion , K&N short ram intake , true dual exhaust with flowmaster mufflers , URD o2 sensor simulator
    Hello all im new to the site but i figure this is the best place to get some help with my Tacoma . Yesterday i noticed while under slow acceleration or just giving it enough gas to maintain a speed between 20 and 40 mph it will shake badly but as soon as I let off the gas or give it more gas it goes away . its not always the same kind of vibration ...sometimes a slow vibration when going around 20 mph compairable to driving on a washboard road and sometimes when going faster its a faster vibraton. ANY thoughts or information would be very helpfull !!! thanks
  2. Nov 10, 2011 at 12:39 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    welcome to tw,check your carrier bearing located on the drive shaft.
  3. Nov 10, 2011 at 12:59 PM
    klim83
    klim83 [OP] Member
    Louisiana
    Ive messed with it , it has movement but you have to push and pull somewhat hard to move it ....Is that normal or is it not supposed to have slack at all ??
  4. Nov 10, 2011 at 1:23 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    thats sounds ok,i have a little in mine as well.it would be really sloppy if it was bad.not sure whats going on for you.this might be a stupid idea but did you check your lug nuts?:notsure:
  5. Nov 10, 2011 at 3:01 PM
    drwoodr
    drwoodr Well-Known Member
    Pennsylvania
    2012 DC 4X4 SR5
    side steps, heated seats, tonneau cover, rocky mounts, RAAMMat, 12v outlet in dash
  6. Nov 10, 2011 at 4:54 PM
    klim83
    klim83 [OP] Member
    Louisiana
    Yeah that was one of the first things i checked ...I also checked for worn wheel bearings , suspension componants the only thing i found is a small amount of slack in my passenger side tie rod ....other then that nothing out of the normal as far as i can tell ..My take on it is that its within the transmission , driveline , rear end or wheels it changes with speed and not with engine rpm's.....im stumped....
  7. Nov 10, 2011 at 5:01 PM
    klim83
    klim83 [OP] Member
    Louisiana
    @drwoodr ..Thanks ..That makes sense with the tranny mount ...im going to look into that ... this may sound stupid but whats a TSB ?
  8. Nov 10, 2011 at 5:08 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    technical service bulletin. welcome btw!
  9. Nov 10, 2011 at 5:10 PM
    klim83
    klim83 [OP] Member
    Louisiana
    Thanks
  10. Nov 10, 2011 at 6:45 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  11. Nov 11, 2011 at 9:09 AM
    klim83
    klim83 [OP] Member
    Louisiana
    Well now a new problem came to light today ...While driving my truck clunks while shifting gears off and on , mostly when downshifting and sometimes when i am just cruising donw the road i feel the same clunk from time to time ....
  12. Aug 15, 2018 at 5:30 PM
    Shawnerb34
    Shawnerb34 New Member
    2009 double cab 4x4
    Stock
    I was wondering what your solution was I’m experiencing the same thing in my 2009 double cab
  13. Aug 15, 2018 at 7:40 PM
    devkurf
    devkurf Member at Large
    midwest
    Could be slop in a u-joint. When you go from power to the wheels to engine braking, the force on the driveshaft would be reversed, and that could cause a clunk.
  14. Aug 15, 2018 at 8:16 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    I'd try full throttle all the time, don't let the vibration have time to get a foothold ! This way the real problem will show itself much sooner, and you don't have to waste time looking for trouble, the trouble will find you!!! And, instead of wasting time looking for trouble , you'll be getting exercise walking.
