Help: Suspension Making Noises (with video)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rogerkamp8817, Feb 22, 2014.
  1. Feb 22, 2014 at 10:08 AM
    rogerkamp8817
    rogerkamp8817 [OP] Well-Known Member
    Orange County, California
    2010 Toyota TRD Off-Road 4x4, AC, Superwhite
    My suspension is making weird noises when going over speed bumps. I've checked the torque on everything I possibly can. Everything seems tight and torqued properly. I removed the swaybar thinking it might be bad swaybar links, but the noise is still there.
    I attached my GoPro and shot some footage of the suspension going over speed bumps. The video also captures the clicking sound that I'm trying to fix.
    Here is the video:
    http://www.youtube.com/watch?v=YulE6U64yKU
    What do you guys think is the issue? I think I have an idea but I want to hear from you guys.
    Specs:
    2010 Toyota Tacoma 4x4 Access Cab TRD Off Road
    Icon 2.5 in coilovers
    Dirt King UCA
    Thank you.
  2. Feb 22, 2014 at 5:08 PM
    rogerkamp8817
    Any thoughts?
    I see a lot of movement in the lower control arm bushings where it connects to the frame. Or is this typical?
  3. Feb 22, 2014 at 5:30 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    When I watched it I was thinking it had to do with the LCA. I thought the LCA was moving way too much but I am not familiar enough to make a diagnosis. Here's a bump.
  4. Feb 22, 2014 at 7:52 PM
    rogerkamp8817
    that is what I'm thinking too.
  5. Feb 22, 2014 at 8:02 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Either excessive play in that front control arm or its excessive clearance on your differential needle bearing and axle.
  6. Feb 22, 2014 at 10:07 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    it almost looks as if the bushing is barely there. There should be a little play but that LCA is "moving" back and forth. maybe get a LCA/UCA poly bushing kit?
  7. Feb 23, 2014 at 1:44 PM
    rogerkamp8817
    I just re-torqued the alignment bolts. One was around 80 ft-lbs. I re-torqued it to about 105. Drove it and still heard the noise. I re-torqued it one more time to 120 (100 required). I think there is a slight improvement, but it might be in my head. Here is a new video with slow motion shots.
    Replacing the bushings looks very difficult (especially when I don't have a garage to work in).
    http://www.youtube.com/watch?v=3yKim88FBMo
  8. Feb 23, 2014 at 1:52 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    That bushing movement is normal.
    I'd say it has something to do with your axle moving around in the diff. There is a small amount of movement in and out of the diff but yours might be excessive.
  9. Feb 23, 2014 at 1:56 PM
    rogerkamp8817
    How to I check the axle movement? Can I grab it and shake it or do u need to disassemble it? Thanks
  10. Feb 23, 2014 at 1:56 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Have you checked the upper ball joint? In the first vid I thought I could detect some movement.
  11. Feb 23, 2014 at 1:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    just grab the tulip and pull it in and out. There should be a very small amount of movement.
    I also agree about checking the ball joints, specifically the upper. Maybe even jack it up and pull the castle nut off to make sure the tapered shank is still pressed in the upper arm.
  12. Feb 23, 2014 at 2:04 PM
    rogerkamp8817
    Yes the upper uniball and uca assembly has maybe 10k miles on it. Bought it new about 6 months ago. I checked the torque and apply dry silicon to the uniball every other car wash.
    What is our basic power train warranty? 5 years 60 K miles? I'm just below that mileage. Maybe I'll bring it to the dealer if this warranty applies.
  13. Feb 23, 2014 at 5:32 PM
    rogerkamp8817
    I wiggled the "tulip" of the axle where it connects to the front differential. it feels like there's about a quarter inch of wiggle, and I think I've found the problem. I'm going to bring it to the dealer tomorrow. I hope they will replace it under warranty.
    I'm not sure how this could have happened. I rarely use 4WD. The coilovers areset at their default height. I didn't crank them up or anything.
  14. Feb 23, 2014 at 5:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Can any other second gen guys confirm that 1/4" is too much movement?
    My first gen doesn't move that much.
  15. Feb 23, 2014 at 6:06 PM
    rogerkamp8817
    Wiggling it produced a unusual sound, almost like the sound I'm trying to identify. This leads me to believe the axle is the problem.
  16. Feb 24, 2014 at 12:37 PM
    rogerkamp8817
    The truck is at the dealership. They are saying the movement is normal in the CV axle... I will head to the dealership end of today to discuss this with them. My approach is to crawl under a new truck and see if the axle has that much play and compare it with my truck. Any thoughts?
  17. Feb 24, 2014 at 12:42 PM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Good luck getting the dealership to replace anything they said my driveline vibs were normal too a while back
  18. Feb 24, 2014 at 12:49 PM
    CVYota
    CVYota Damaged Goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Did you check the nut holding the UCA in the back(the long bolt going through the 2 arms)? I had a similar issue and found the nut wasnt torqued properly, and the UCA rattled over every bump.
  19. Feb 24, 2014 at 1:10 PM
    rogerkamp8817
    I've checked the UCA bolt (the one that is a foot long or so). It is torqued to 85 ft-lbs. I'll increase it to 100 ft-lbs and see if that makes it any better.
  20. Feb 24, 2014 at 5:46 PM
    Elicarpenter2234
    Elicarpenter2234 Member
    Eli
    Brooklyn ct
    05 Tacoma TRD OR
    3" billy's lift, billet grill,LED Gauge cluster, black housing headlights
    in the slow motion video i noticed that the LCA bushings is not onlt moving an excessive amount going up and down but it is also moving sideways as well. if the dealership wont do anything about it i would disconnect the bottom of the strut and upper ball joint and the abs and brakeline brackets and use your best judgement of resistant pushing down on the control arm. i just did my suspension lift over the weekend and my truck is an 05 with 70k on it now but i could barely move the control arm.
