Help swapping spindle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgrande, Mar 29, 2010.
  1. Mar 29, 2010 at 6:39 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I started to install my OME lift + driver side spindle today but I'm stuck on the spindle part :mad::mad::mad:. I need some help. After alot of struggling, I went to auto zone and got a wheel puller to help pull off the hub so I could get the spindle off. BUT I CANT GET IT OFF. I was able to get it to where the axle is lose and moves back and forth in the housing, but I still have no idea how I'm going to get this spindle off.
  2. Mar 29, 2010 at 6:52 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Try this tip: Wind down the large nut until it sits flush with the bottom of the bolt. Take a hammer and hit up on the bolt. The nut will act as a large washer. Don't hit too hard though as you don't want to damage the bolt .
  3. Mar 29, 2010 at 6:59 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    the nut on the axle? I already have the axle lose. Byt I think I may have been doing it wrong. Does the part that the lug nuts for the wheel come off or the piece directly behind it with four bolts connected to the spindle?
    Also, how do you get the ABS sensor off??? I tried to pull it off for a while and got nowhere.
  4. Mar 29, 2010 at 7:10 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
  5. Mar 29, 2010 at 7:19 PM
    SpaceMonkey
    Houston, Tx
    06 PreRunner
    Oops, I read your post wrong. My bad. I guess I can't help you out.
  6. Mar 29, 2010 at 7:23 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    be very careful especially w electrical components. wat year/make/model u got? i think they kinda changed designs in between production years. posting pics will help
  7. Mar 29, 2010 at 7:24 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    its an 09 trd 4wd
  8. Mar 29, 2010 at 7:24 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    hey I did the install a few weeks ago, can you take a pic of the part you are hung up on?
  9. Mar 29, 2010 at 8:07 PM
    Wrencher86
    Wrencher86 Active Member
    Chicago, Il
    '10 4x4 5Spd Reg. Cab 4cyl.
    These thing don't have spindles. They have sealed bearings. You have to unbolt it from the knuckle and then either chisel it out or use a slide hammer. As for the ABS, there should be a retaining bolt on the hub. remove that and then CAREFULLY pry on it with a SMALL screwdriver. You can try tapping it with the handle of the screwdriver too.
    EDIT: Wait, you are talking about the wheel bearing, right?
  10. Mar 29, 2010 at 10:04 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
  11. Mar 30, 2010 at 3:51 AM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    I was trying to take the hub off wrong I think. I'm going to go for the four bolts today.
  12. Mar 30, 2010 at 3:53 AM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    On the second link for the ABS sensor, Ive tried disconnecting it, but it wont budge. Is it ok just to unbolt it?
